Jet 1220 chip deflector
GalenV
>Am I overly concerned or has anyone made a chip deflector to keep chips from pilling up on the Jet 1220 motor and eventually into the motor fan. The motor fan does not put out enough air flow to blow away the chips.
If someone has made up a chip deflector of some type I would be interested in seeing what you did. Not much space and maybe it just would be more of a trap to clean out.
Also has anyone made an extension to the light or relocated it on the bed. Seems the flex conduit will not let you move the light to show inside a bowl. Well, unless you put it low and upward and fill it with chips.
Thanks if you have comment on either item.
Galen
