>After attending a Bonnie Klein workshop, I got one of her threading jigs, and a new 1220 vs lathe. The on/off switch has failed. The WC store repaired it before I got it (new switch), and the new one failed as well. The repair guy said it is the bimetal in the switch which heats up and warps and then doesn't warp back, too much current for that switch. Any one else have this problem?
>Not on my Jet Mini (don't use it very much) but I had a similar failure on one of my drill presses. I took the switch apart and could not repair it since heat had warped and melted things. (Poor contact=increased heat=poorer contact...)
I couldn't wait to order a factory replacement switch so I bought a good quality switch from a local company that services industrial motors and other electrical equipment. You can find switches in a variety of packages and amperage capacities. There is plenty of room on the Jet to accommodate nearly any switch, perhaps with a bit of filing. At worst case, you could use a standard household light switch and mount it in a plastic outletbox fastened to the lathe, but it might look ugly and it might not be safe. (might get bumped on accidentally) A slightly recessed rocker switch is safer if you can't get a factory replacement.
In my case I cut a rectangular hole in a piece of plastic and used it to mount the switch. Since the space on the Jet is open in the back, you would have to be careful to shield the wiring from accidental finger contact, as Jet did with the plastic box.
BTW, the local Jet service guy told me switch failure was fairly common on these machines. He said sometimes dust gets inside. It might be worth disassembling to check and see if it can be fixed. Fine dust got into my Jet 1642 switch and caused it to fail but I was able to get it apart (with a big effort) and fix it.
>John, thanks for the tip re. the 1642 switch. After two failures, I second your advice to Reed to replace with alternative type switch. Had a problem recently with drill press switch (poor design IMHO), and managed to modify the internals slightly to correct same.
>I had a similar switch failure in my older Jet mini. The power toggle switch was undersized for the application. I bought a replacement switch with the same form-factor (dimensions) and a higher power rating, and I haven't had a problem since. As I recall, I got the switch from the hardware store or home center in a blister pack for about $5.
>If the lathe is new and you have local service that knows the toggle switch is under rated I would let them buy the better switch and put it in.
Tell them you want it that way to keep in warranty.
I have the 1220 but not with electronic variable speed. With the dust I can make I wonder how you keep the open control box free of dust. Maybe your manual says to blow it out on a regular basis so the board does not overheat.
There can be a down side to mine as the switch seems to be at the right height that if I am hollowing a form or even on some bowls my side hits the switch and surprise!
May need to move my switch, take a new stance or loose some weight. :)
>A perhaps loosely related example is the chronic failure of the PM3520 remote switch, notorious for being disabled by dust. The mustard monster site http://mustardmonster.googlepages.com/ discusses many solutions to this under the Electrical page. What has worked for me now for 2 years is a heavy duty sandwich bag sealed over the box. I have had to replace the bag once or twice. Not pretty, but seems to work. Maybe Jet will supply some sandwich bags for future models.
>I just got the new 12/20 VS and took it out to teach a workshop and the switch failed on mine the first day. I needed to fix it ASAP so I just opened the box and saw how the switch wires were clipped on. I want down to Ace Hardware and bought a new one to fit in the space of the old one. I took the bad switch apart later to see what went wrong and I think the slamming of the VS box against the lathe to close it had jared the internal clip contact out of position. I took the control box off the lathe and screwed it to the table. All works fine now, I am very pleased with the 12/20. The 3/4 HP is much better then the 1/2 on most minis.
