New Beal Buffing Wheels...Question
Joe Pack
>I just started using a new Beal buffing wheel set. All three wheels seem to be slightly out of round...I can feel the "bumping" on the wood as the wheels turn, and the bars, tripoli especially, show that some areas of the wheel are taking the compound while other areas are not. Also, the new wheels throw quite a bit of "trash", i.e., strings coming off.
I am sure these conditions are typical, and will eventually disappear as the wheels are used. I wonder, though, is there some suggested way to speed things up to get rid of these annoyances sooner?
Re: New Beal Buffing Wheels...Question
Mike Jones, Redding, CA
>Joe,
It's most likely that you don't have the wheels centered on the mandrel properly. But my best advise is to call the people at Beall. Let them know also about where you bought them and when. These people have ALL the answers to your buffing questions.
1-800-331-4718 ( 9:00 - 5:00 EST)
Dick Hines
Dick Hines
>As far as trash. When you get your wheel runing true take a piece of 60 grit sandpaper and wrap it around a block of wood and rub it on the wheels. this will help with the trash. Atfter you use the wheels if you have any build up of compound use a old saw blade to scrape it off while the wheel is turning.
Go light with the compounds. Just a very light touch is all you need.
Brian Hahn in SW Wisconsin
>40 grit sandpaper also works well for getting rid of the "trash".
I also use 40 grit to remove excess buffing compound.
Your last statement is really important: use a light touch when applying the compound. Too much compound makes the wheel grab the piece more, leading to pieces flying out of your hand.
A light touch of the piece against the wheel is also important. It's like using sandpaper - a light touch does the job and doesn't cause as many problems (like flying pieces).
>I've used a clean hacksaw blade to "dress" the buffing wheels.
Thanks for the help.
Joe Pack
Rik - WI
>I used a vacuum/dust collector attachment to both dress the wheels and minimize the amount of air borne trash.
Take care,
Rik
Dick and Joe, I use a
Allen Neighbors
>40 Grit sanding belt to clean my wheels. I also used onea entire belt to make a homemade wheel round, after I messed up centering it on the PVC axle. I cut the belt, to make it one long strip, and just hold one part of it against the wheel. One belt lasts a really long time, and works better than the saw blade for me.
I buy them (40G) just for cleaning my wheels. The one that requires most cleaning for me is the tripoli wheel.
