Insect id? *LINK*
Insect id? *LINK*
Insect id? *LINK*
ILYA ZAVORIN
>I managed to take a decent picture of the insects described in my previous posting (see link below). Does anyone know what these are? I live near Washington, DC. Thanks much.
http://www.woodcentral.com/cgi-bin/turning3.pl?read=192681
Re: Insect id? *LINK*
Re: Insect id?
arkie
>Termite. You can see the bottom remains of where the sawdust tunnels were on the top left view.
Re: Insect id?
ILYA ZAVORIN
>Arkie, according to one of the responders to my original posting, termites hate direct sunlight. I saw these insects during daytime, including when the photo was taken. I saw them a day or so after I kept this piece of cherry submerged under water for a few days, but not immediately after, so I don't think they were too distressed to come out if they usually did not. Could these still be termites? Thanks.
Re: Insect id?
arkie
>I don't think it's sunlight that termites avoid, but drying out. Normally that goes with sunlight. They look like every termite I've ever seen, except the winged alates. Check http://insects.tamu.edu/fieldguide/aimg26.html
Steven Antonucci
If that's not a termite, then I've never seen one
steve antonucci
>Look exactly like every termite I've ever seen...
Steve
They look just like Georgia termites
Gil Jones...Georgia
Termites
Randy Johnson Connersville IN
>Since you found the wood along the road I'd guess that it fell off a load of firewood being hauled. A lot of the probably had termites. If you are seeing them out in broad daylight it might be that they are trying to figure out what happened to the rest of the colony.
One more thing
>My shop is a former two car garage that would probably have fallen over by now if I had not rescued it. It had a REALLY bad termite problem. So bad that the handle of an old pick laying on the floor was reduced to mud and dust. Needless to say, one of the first things to be done after the initial cleaning out and stripping out the walls and ceiling was have a pro come out and "treat" the building inside and out. It took almost a year (repairing damage)before I was ready to start moving in.
The floor, not suprisingly for an older structure, had a few cracks of various width. Several months after all the machines were in place and running I was still moving boxes of stuff from the old shop. One day, thinking nothing of it at the time, I set a cardboard box on the floor over one of the cracks and left for the day. A few days later I picked the box up and found the bottom destroyed by termites. I'm sure these were part of the original infestation that were trapped under the floor by the blockade approach to termite treatment. A few days later I found the start of a freestanding tunnel near where the box had been. I sprayed the cracks myself and have seen no further evidence of termite activity.
The bottom line is that if you have ANY doubts about a possible infestation, call a pro. Fixing the damage afterwards is a royal pain.
Rob Wallace
Rob Wallace
>Without question, these are termites. No pigmentation, no pinched abdomens, proportionately large heads (relative to body size), "manly mandibles", lack of wings, etc. (Order Isoptera) - see the Wikipedia link below. No possibility of these being carpenter ants, BTW.
The comments about drying-out are valid, an the aversion to light is also true. Presence of mud-tunnels on a structure's foundation is one of the few normally visible telling signs of termite infestation.
Good luck with the found wood. If it were mine, I'd be getting rid of it as fast as I could. In addition to John Jordan's "Life's too short to turn crappy wood" mantra, I would propose the first corollary to Jordan's Rule, "Life is WAY too short, and potentially more expensive, to turn insect-infested wood".
Rob Wallace
Wikipedia 'Termite' Entry
Re: Insect id?
Tony - Memphis
>Unfortuneately, I have learned a lot about termites. Those look like termites to me too. But, I wouldn't be the least bit concerned over them. The only way that the common termite can "start a new colony" is when they swarm (usually in the spring - April here in the mid south). At that time, certain members of the colony turn black and grow wings and then leave the colony (in a swarm) and fly off to start a new colony. The workers that you have are very harmless. Actually, if you leave them sitting on the concrete for a while, they will most likely die. They need moisture to live. Contrary to popular belief, they don't live in your walls, they feed there and then return to the colony in the ground where its nice and dark and moist. If you don't alrady have a termite contract, I would suggest that you get one! We switched to Termidor, which as someone else mentioned, is supposed to kill the colony. Hope it works! I've seen swarms in our yard, but these guys are easily carried in the wind. You can have them 2 inches from treated ground and your fine. Anyway, I don't think its anything to get excited about. I really wish I knew nothing about termites, but its a part of life around here.
oh, to qualify..I'm not including the formosan (spell that?) termites in this discussion. Those do live in your house and don't need to be in the ground. Fortunately, they aren't a problem here yet.
Tony
Re: Insect id?
ILYA ZAVORIN
>Well, I have a dilemma. I called a pest control company and they came for an inspection today. They did not find any mud tunnels on the side of the house, any signs of damage on the inside. However, when they started turning over a dozen or so logs that I've placed along the edge of my patio, they found the same white termite workers under one of them. This particular log was very close to the lathe that I also keep on the patio year round. it's close to the edge of the patio too and has some shavings underneath and around it. So the guy said that this is an indication that I might have a colony that has nothing to do with the termites in the cherry log. Also, I have a shed at the edge of my property that is made of wood and has green logs stored both inside and outside along one of the walls. Finally, I have a small veggie garden that is surrounded by small wooden boards. Several of them have completely rotten and also, according to the pest control guy, have what looks like termite tunnels all over them. One thing I forgot to ask him was how do we really know that the termites under the log are from a different colony and not just migrated from the cherry log. But even if they are the same, it looks like I am playing with fire here and should probably go for a treatment like Centricon (sp?) both around the house and around the shed.
Re: Insect id?
Barry Elder
>Here is Florida it is not unusual to find "termites" in any dead wood. It is another thing to find termites in your house! Ask your termite pro if there is a difference in the varieties or would the termites in your logs have to swarm to infest your home? A "little" information is a dangerous thing with termites. Ask as many questions as you can think of. Check your local library.
Re: Insect id?
Tony - Memphis
>They don't have to swarm to get in your house. Sounds like there are termites in your area (as is the case in most parts of the country) and if it was me, I would start a treatment plan presto. Wouldn't hurt to get some quotes. They vary greatly. I am not qulaified in any way shape or form to suggest one treatment over another, but I have done lots of reasearch and found that Termidor seems to be the treatment of choice these days. I don't trust the baiting systems. The other big issue is the reputation of your agent and the insurance they carry. My guy told me plain and simple thta he couldn't keep termites out of my house 100%, but that he would cover any damages. So basically, you are buying a package of treatment and insurance from them. So, make sure they can/will cover any damage. My guy just switched to Termidor from Premise. He re-treated our house and shop year before last. No treatment will completely eliminate termites, so you'll still see them and even see a swarm now and then in the spring. Important to let them know if you see some so they can come spot treat if needed. Oh, one last thing, the treatment instructions are pretty specific. Make sure your guy follows the instrcutions from whatever material they use. When ours was redone, he had to drill more holes in the adjacent concrete (sidewalk, driveway, etc.), but he didn't have to apply any material into the holes in the walls (other treatments require that). He put it in our walls anyway since we had an issue!
Termidor has a good web site.
Tony
