Re: Do You Care How Long It Takes?
Fog Tanner
>I would have mixed feelings about the question. When I was younger I worked in machine shops running where speed and quality was everything. I would make 1000 of the same thing, yet each one was if it was the only one I had done. Even though it was repetative, there was always the challenge of making each match the print within tolerances. It was actually enjoyable and a challenge the faster you could go.
I do some production turning from time to time for the fun of it. I will make a run of 100 toothpick holders for which there is no deadline and I will give away. But, I do them as quick as I can and as well as I am able. They are in a way practice with the tools. They are also each a journey of their own as each is a little different shape - yet similar. It is a joy watching the shavings come off, yet the aim for each cut is to improve upon the last. In looking at the reach for speed, I looked at how long Raffan had been turning and our age differences and figure I will be able to catch him in pnly about 30 years - we will both be dead by then.
Roughing bowls is much like production turning in speed. But, I still find the time to practice cuts which will be used later in finish turning. Each one is a new adventure and a lesson to be learned. It is up to the individual as to how long to dwell.
These days I spend most of my time in offcenter work, where even going fast is still slow. Each piece is a new journey, even though the path was traveled many time before. Each piece of wood brings a new discovery in the way it reacts. There is a process of finding the best way to cut that piece and then perfecting that as best you can, knowing that the next will be a little different. In these forms I find a bit of a pardox, speed versus the challenge of turning a single blade fan. There is a rush to get to the basic shape and then the majority of time consumed in all the little problems and small cuts when the walls get thin. This creates a problem as there is "what if" and "if I change that" time and the rush to finish to get to the next one.
The day job is programming and problem solving, where speed is everything. I have worked on problems which took me less than a minute to resolve. But, I have also worked on projects which ran into months of 18 hour days and seven day weeks. In either case you run flat out as if there is no tomorrow, as there is always a new problem when the current little issue is solved. There is a certan amount of passion that drives the quest for the answer, and each problem is looking for an answer. So each one is a passionate quest into the unkown. Einstien once said that the most beautiful thing we can perceive is the unkown. From that point of view each problem or piece of wood is beautiful, for they are both based on the unknown. Were it known, there would be no problem and piece of wood a bowl.
At times I look at wood turning in much the same way, there is always one more piece to turn - each with its own little mysteries and journeies to be enjoyed. But as qucikly as they are finished, a new one will appear to keep the mind active. While not for everyone, for some it keeps the mind active and learning past "our years", for when you quite learning or loose the passion for life the only thing left is the grave.....or a government job.
Fog
