Termites in wood?
ILYA ZAVORIN
>A few months ago I found a piece of cherry with some burl in a ditch, brought it home and put it on my concrete patio. The piece appeared to have some insect damage but I did not pay much attention to it. Then a few days ago I discovered white insects crawling all over it. They looked sort of like ants, not more than 1/8" long, white/creamy color with a round head and an elongated body (unfortunately, my camera can't do macro, so I could not take a good enough picture of it). I tried looking them up on Google images and found a couple of conflicting references. One had a picture of something that looked similar and stated it was some sort of ant. The other had a different picture, but also similar, and said it was termites.
I completely submerged the piece in water for a few days hoping that this will kill them off. Then I drained the water, and in a few days the critters reappeared. At this point I think I want to get rid of the piece, but even if I do, I am not sure I will still be left with termite infestation of the property.
I did not notice these insects anywhere else including other logs stored on the patio, although I did not every single one of them closely.
What should I do at this point? I have a few logs on the patio. I can get rid of them, but I prefer not to do it if that can be avoided. If I order a termite/ant/whatever inspection of my property, will they be able to inspect only the house or the surrounding areas as well? Should I treat the logs with some deadly chemical?
Thanks much.
