Examples & ways to autograph my work?
Ray Carson, Lawrenceville, NJ
>What are some ways that you "sign" your work? Ellis has a VERY unique inlay that I love, but wouldn't attempt with my current skills. If you have some PICS, please post. Does anyone know of something other than paint that wouldn't chip off over time? There is no recess in the bottom of my turning to protect the autograph.
Thanks,
Ray
Re: Examples & ways to autograph my work?
Carole Valentine
>I use a burner for my signature and the type of wood. No matter what type of bottom you have, unless it is a round bottom, it should be slightly concave or recessed so the piece sits without wobbling. This minute recess also protects the signature.
>Carole, do you use burning for walnut? JKJ
Carole Valentine
>John, I don't turn a lot of Walnut any more but when I do, on really dark Walnut, I use a gold pen, mask the base and spray a quick coat of clear lacquer over it. If the Walnut is not too dark or has light areas I will use my burner. I have also used an engraver but don't like them.
signing work
>Ray Here are some photos I did a few years ago of the ways that I have signed work. I use the Dremel engraver mostly. If you want a bolder looking signature rub gold or silver wax into it. I prefer the more subtle look. I have used pens and burners but now stick mostly to the engraver. It does take practice. I find a very gentle touch does best and it works better if the area you are writing in has been sanded well.
The top two in the photos were done with the engraver and the bottom 2 were burned.
Steven Kubien
>My method is very simple... A Staedtler (sp) pigment pen, 0.1mm. It can be found with the drafting supplies at Staples, Business Depot etc. It has archival ink so it will last forever and only costs around $5.
HTH
Steve Kubien
Re:Staedtler Pen......and I'm an old
>school draftsperson who learned on a board with a T-square. I didn't think of that one. I have a full set of pens sitting in my work desk.
I'll have to try a sample piece and see if it bleeds.
Thanks Steven.
Ray
Re: Burner - What if I don't own one?
>Could I substitute a soldering iron with a sharp tip? :-)
Re: Thanks for the PICS John
>I was hoping someone would post some. Gives me and idea of the info. to put on a piece. Short sweet and to the point. I like the burned look better. Looks clean.
Ray
Richard Allen
Re: Burner - What if I don't own one? *LINK*
Richard Allen
>Yes you can. But a sharp tip is more likely to follow the grain than a rounded tip. A cheap woodburning pen with screw on tips can be "adjusted" for signature work and still be used for some pryo work.
An example of a cheap pen.
Cheap woodburning pen
Rob Wallace
Rob Wallace
>I use a #5 Pigma permanent black (archival) pen that has a 0.45 mm tip. These are purchased in an art supply store. I write in a circular band of my signature plus other necessary writing (name of piece, species, and date) just inside the foot ring of the piece after it has been sanded to at least 600 and sealed with shellac. Just prior to signing, I "rough-up" the bottom surface with 0000 steel wool. After signing the bottom, the piece gets a few spray coats of lacquer which heightens the contrast of the black ink against the background and protects the writing.
If the wood is particularly dark (walnut, wenge, blackwood, etc.), I use a carbide tip vibrating engraver to do the writing, and then fill the engraved depressions created by the engraver with metallic gold rubbed-in filler. (This is the technique I learned from Cindy Drozda.) The bottom is then sealed with lacquer.
I have never liked the effect I get with signing pieces using a woodburning technique.
Rob Wallace
Carole Valentine
>When some folks were here in June, we did a collaborative piece that everyone signed on the inside of the bowl. We used a very fine tipped pen that Mac Ray had, and it worked wonderfully and was not affected by the oil applied afterwards or the buffing. I have forgotten the brand name of the pen, but would like to get a couple of them. Going to have to ask Mac (again) what it was.
Bill Noce Northeast Ohio
>I use a Pigma Micron .005 #1 Archival Ink Marker, it has a very fine tip great for writing small. Purchased at Pat Catan's or Michael's craft store or any craft store.
Carole Valentine
>Thanks, Bill. That was not the brand but sounds like it would be what I want. Can probably get it from the local art supply store.
Steven Kubien
>No bleeding that I have found, even on unsealed wood.
Steve
Ken Grunke from SW WI
>Most soldering irons I've seen have a handle that's too far back from the tip to have good control and they might be too hot anyway. Try it, see if it works for you.
John Veerkamp, Western Mo
>Carol,
I use Micron Archival Pens. They are made by Sakura Corp. They come is several degrees of fineness. These pens are available in quilt stores and maybe other fiber art stores.
John
>Usually called Pigma pens by quilters.
>I tried the cheap irons and then tried a less expensive brand name woodburning kit. I could not write my name and make it look decent. Then I bought the Optima woodburner. What a difference.
Re: Pen - Thanks again Carole :-)
Ray Carson - Lawrenceville, NJ
Thanks everyone. :-)
Here's another option, Ray *LINK*
>Rick Herget is a master engraver who used to advertise here. For a pretty reasonable price, he'll make you a custom branding iron. I use one of his irons with my rosebud logo on my turned pieces, because inlaying ivory into turned objects is beyond the pale. Rick will cut you an iron with or without electric (controlled, not to be discounted) heating. You can give him your signature or an image or logo you want to have on your work.
Cheers,
PS Tell him I sent you.
Herget's Custom Branding Irons
Re: Here's another option, Ray - Thanks Ellis!!
>I have a torch heated one I bought years ago but it's too..."sterile." I want something with a little more pizazz!! Plus mine has seen better days.
Thanks again big guy. I'll be sure and mention your name. ;-)
Sincerely,
Ray
