Wood ID from leaves
Wood ID from leaves
Wood ID from leaves
ILYA ZAVORIN
>Location: near Washington, DC
Leaves are about 4" long
Thanks much
Re: Wood ID from leaves
AndiWolfe
>Looks kind of like an oak from the gestalt, but I'd need to see the buds up close to make a more informed guess.
>Hard to tell from the picture since the leaves are withered and bunched together. They appear to be palmately compound, that is, several leaflets radiating from a point such as in the buckeye/horsechestnut family.
Buckeyes generally have 5 leaflets, sometimes 7, and occasionally more (Texas Buckeye), most are 2-6 inches long. However this leaf doesn't appear to have wider leaflets the sharper point typical of buckeye.
Or do the leaflets instead grow from several nodes instead of one? If so, how many leaflets grow from each node? Are all the leaves on the tree like this with several on the end of a twig or were there more leaves growing along the twig that came off?
Are these leaflets smooth on the edges or sawtoothed? Are the edges fairly straight, ovate, or undulating?
How big is the tree?
Was there any fruit or nuts? Shingle oak leaves can look like that, but are alternate.
Was this a cultivated tree in someone's yard? (Could even be an obscure cultivar, hard to ID.)
The best thing to do if you have some of the wood is to use a razorblade and slice the end grain of a small piece and look at the pores. Knowing whether the wood is ring porous or diffuse porous can narrow the search.
Ray Binnicker
>I vote for the Willow Oak.
Ray Binnicker
ILYA ZAVORIN
>John,
I am attaching a hopefully better photo of the leaves. You questions:
1. The tree was very tall, I think about 17-18" in diameter at the bottom.
2. Leaflets are smooth and fairly straight.
3. I did not find any fruit or nuts under the tree. By the way, the tree has lost more than half of its foliage and the leaves on the ground are brown, like oak.
4. There are several such trees in a straight line in front of an apartment building, so they were most likely planted.
Thanks!
Ed Karch
>Ilya
It is willow Oak. A common street tree in the DC area.
jim miles
Jim Miles
>Yes - Willow Oak- Have several in my yard
Get to rake lots of leaves, a real pain them being so small
Wood is fairly plain, heart wood will have some darker color. Willow Oak has distintive unpleasent smell - my daughter calls it the cat litter box wood
