I am busy considering either the Nova or Jet 1642 lathes for purchase.
I could not find or see how the Jet tailstock is aligned. I did find a procedure for the Nova lathes which seem a bit dodgy.
My current lathe, a old Delta has 2 screws on either side of the tailstock for adjustment.
I would appreciate if any of either the Jet 1642 or Nova turners would elaborate on the procedure. Bear in mind that I am in South Africa where support is not great so we do not have the resources that you enjoy in the states - therefore my concern
>I really didn't have much trouble with my Jet 1642 being out of alignment. But it did get a little out of alignment after I moved.
Basically, what I did was roughly level the lathe on the floor in the place where it was going to reside - you don't want to move it afterwards. I then brought the headstock a bit in from the end and locked it down. I inserted a good drive center.
I inserted a good live center into the tailstock. I moved the tailstock so that the points of the two centers were a couple of inches away from each other and I locked it down. I then used the handwheel so that the points were almost touching.
You unlock the 3/8" nuts on the feet. You then play with the height adjustment of the feet. You'll want to check the horizontal deviation and the vertical deviation. You basically play with the feet until the two center pins are aligned. After they are aligned, you lock the feet down, making sure that you don't disturb your alignment.
You have to make sure that the 1642 is at near the right height and is placed where you want to place it in your shop. You wouldn't think that adjusting the feet would make a difference - I didn't until I tried it. I got the procedure from one of the guys at the WMH Group tech service.
>When I set up my Nova DVR 3000, the earlier version, I simply leveled the bed of the lathe both end to end and across the bed until it was level in both directions. Then both the head and tailstock aligned perfectly. It is very easy to throw your lathe out of alignment by having the bed twisted a slight bit. Through careful alignment, you can generally fix slight alignment problems.
I suspect that is what the 1642 owner did to align his lathe when he adjusted the feet until they aligned.
>There are at least four Nova owners in our local club that have never had a problem. My Nova however, gave me fits with different approaches to attempted alignment. (the best I ever achieved was .006 out vertically, .002 horizontally) Be aware that you can adjust the horizontal with the adjustment screws, but not the vertical. In the end, I kept a box of precut brass shims, and when alignment was critical, I shimmed each time I moved the tailstock.
One day, about two years ago, I brought home my "Mustard Maiden" and set her up where the Nova formerly sat. That afternoon the dark grey cloudy skies broke open and sunshine poured into the shop. I heard a chorus of angels, and saw a warm golden light surrounding the point where head met tail (perfect alignment!).
Both my Jet 1642's seemed to align perfectly (by eyeball) when set up on a concrete floor. However the cast iron bed can deform a bit if not evenly supported. The method that JL described (by adjusting the screw-in feet on the legs) should solve any minor miss match. Being relative short of stature, I do not use the screw-in feet.
I bought a double ended Morse Taper 2 gizmo for just that reason for my DVR3000. So far I've never had to use it I've always had perfect alignment. I bought it from Teknatool or Packard Woodworks, can't remember fur sure.
