Diamond Grinding wheels
Thom Sayles
>I talked to a fellow turner and he uses a diamond wheel to hone his bowl gouges instead of sharpening then like I do. I'd like to buy one but have no idea of grit to buy and size to buy. I have a 6 inch and a slow speed 8 inch grinder. I was wondering about a source too. Are the ones on ebay ok? I might want to shape or polish rocks with it too. Does anybody use one?
Re: Diamond Grinding wheels
Re: Diamond Grinding wheels *LINK*
Greg Haugen
>I have never used one, I'll make that clear from the start. But in my web browsing a few days ago I came across Andre Martel's site and he carries them. It may be worth an email to Andre?
Not too much help, I know.
Greg H.
Andre Martel's Tools and Supply Page
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>I have one of Andre Martel's wheels and love it. The one I have is 180 grit. I have it mounted on a slow speed grinder -- I believe they are only meant for slow speed grinders. It seems to produce a sharper edge for those finishing cuts. And it removes significantly less metal from tools than a regular grinding wheel. I have had it and used it daily for over a year and have found that the diamond facing is standing up exceptionally well. Go for the solid aluminum wheel. There are no problems with wobble. Some of the guys in our club that went for the cheaper plastic wheel found they had a wobble problem.
Fred Holder
>A couple of months ago, I watched a demonstration with Jack Wayne of the Seattle area. Jack passed around his bowl gouge which he said that he sharpened on a diamond wheel that the purchased from Andre Martel. It had a very fine high gloss finish on it and seemed to be very sharp. I subsquently ordered two wheels to put on my Woodcraft slow speed grinder. Jack had a 180 grit wheel. Andre was out of 180 grit wheels, when I was ordering, so I purchased three with steel frames: 100 grit, 80 grit, and 60 grit. Andre says that it takes about two hours of grinding to get the roughness worn away on the wheels. At first, I got very coarse grooves on my tools with very rough burrs. Now after a month or so of use, and I don't use them everyday, they are starting to give a smoother grind. What I like most about them is that they are 1-1/2" wide, and always flat. Andre has agreed to exchange a 180 grit wheel for the 60 grit, which I've not used, when he gets some more 180 grit wheels in stock.
I did intend to put one of the diamond wheels on my Tormek because the old stone had cracked, but when I learned of the new black stone, I decided to use it instead of the diamond wheel.
I have used the diamond wheels to shape bowl gouges with an Ellsworth Jig on my Woodcraft Slow Speed Grinder with the Martel diamond wheels, 80 grit, and then taken them to the Tormek with the new black stone, SB-250 for a final grind. The new Tormek black stone is more aggressive than the old gray stone that came with my machine and it does a nice job of final grinding to produce a very sharp edge.
I believe a 180 grit diamond wheel would produce an excellent edge on a gouge. Jack was using his 180 grit diamond wheel on an 8 inch high speed grinder.
So far, I am pleased with my diamond wheels, but do wish that I had a 180 grit to get a better feel for how well the finer grit would work.
I should say, however, that I final grind all of my bowl gouges on the Tormek and the new black wheel is significantly better than the old gray wheel that came on my machine, when I obtained it in 2000. As recommended by Geoff Brown, the worldwide Tormek representative, I did purchase a new stainless steel shaft to go with the new wheel. My old wheel had cracked from the rusted shaft. If you have an old Tormek that does not have the stainless steel shaft, I highly recommend following Geoff's advice and replacing the shaft with a new stainless steel one. I do have a review in the November 2008 issue on the Tormek black stones, which can currently be seen at my More Woodturning web site. Just go to the site, select More Woodturning magazine, then select to see a sample copy. The article on the new Tormek stone is on page 27 of the November 2008 issue. Which incidentally has not been mailed yet, but will be mailed on Monday.
More Woodturning Website
diamond - black - Tormek
>>I did intend to put one of the diamond wheels on my Tormek...
Fred,
I wondered how the diamond wheel would work on the Tormek. The Tormek machines I've used, including mine, have a small amount of runout due to the tolerances on the shaft. This is no problem with the standard wheel since it is trued before use. However, I suspect you could not easily true the diamond wheel, at least by dressing, which would seem to limit the usefulness of a diamond wheel
I have a question about the new wheel you mention. You referred to it as a "black" stone, SB-250 in the article, but it doesn't look black in the picture. Is "black" just a name?
I bought a spare wheel several years ago and it is marked SB-250. How "new" is the SB-250 it supposed to be? Do I have the new stone you reviewed?
Re: diamond - black - Tormek *LINK*
Fred Holder
>Hello John,
I was told that the SB-250 black stone was a new addition to the Tormek and it was suggested that I give it a try instead of a diamond wheel on the machine. Geoff told me that diamond wheels had not been too successful on the Tormek. The slight bit of run out you mention might just be one of the reasons why he could not recommend using the diamond wheel on my Tormek. He convinced me that I should try the new SB-250, which works great. Perhaps, I should have tried one of the diamond wheels on the Tormek just to see how it would work. I wouldn't want to run them in water however, since the wheel is steel and not stainless steel.
Did you purchase your SB-250 stone from Tormek or from somewhere else? It may be that Tormek has just adopted a stone that has been around for some time and with Tormek it is new.
robo hippy
>I was chatting with some guys from the UK, and they were talking about a diamond wheel for the tormek made by Peter Childs. Can't remember the price. They seemed to like them, and there was no mention of run out. I have a place here in town that can make them, but they talked me into CBN (cubic boric nitride). Made for grinding steel. They told me it was better for steel, and diamond was better for carbide. My 80 grit CBN wheel is 3/16 inch of material on an aluminum disc. Already spin balanced. An 8 by 1 inch wheel cost $300. It is now in its 4th year, and hasn't worn off 1/16 inch of material. What do the diamond wheels sell for?
robo hippy
Re: diamond - black - Tormek - oops
Oops, I have made a mistake. I went back out to the shop and checked - I have a wheel marked SG-250, not SB-250. Sorry for the confusion, may I blame it on the painkillers?!
I bought this wheel from Woodcraft in Jan '05. Rats, I dislike the idea of having a brand new old wheel on the shelf but I'm not about to throw away the $140 it cost. Don't suppose Tormek would be willing to trade for a new wheel, do you?
I really should not complain since I've been happy with the performance of the original wheel once the tools are reshaped as needed.
>I can't remember exactly, but think it cost me about $230. I checked Andre's website and he does not have prices listed. That may seem a lot, but it is in Canadian doillars. Subtract 25 per cent when you convert into US dollars -- or wait a week and subtract forty per cent!
Joe Melton
>I have bought many wheels from National Diamond in Los Angeles, but not for grinding metal. Their website is diamondtooling.com. There is quite a bit of information on their website, and prices are shown. I think the wheel we would want for sharpening turning tools is the D1A1. These are very high-precision wheels and competitively priced.
Joe
ThomD
>That is the typical machinist wisdom on diamond wheels, carbide, and even stuff like tungsten for welders, but never HSS. Obviously something has changed to get all these products out there for turning tools but just buying any old wheel could be a problem.
Mike Kratky
>Just attended an all work shop with Andre last Saturday,I have his price list in hand: 180 GRIT 6" plastic core is $135, 8" is $190.
6" steel core is $155, 8" is $220 (US dollars)
Andre recommends the 180 grit and there is a "break in" period.
www.public.netc.net/martel
amartel@netc.net
(450)293-2186
