Thread Chasers
Thread Chasers
Thread Chasers
Greg Haugen
>I've looked at Packard and Craft Supplies, so I know what they've got. I was wondering whatelse is available out there, as far as price and/or brand, for thread chasers. I'm looking for probably the 16 TPI set.
Thanks for any advice,
Greg Haugen.
Re: Thread Chasers
Mark St Leger is producing ...
Ed Moore in SW Virginia
>thread chasers, 18 tpi and 20 tpi I believe. They are remarkably clever, it is a double ended tool with the male threads on one end and the female on the other. They come with a very clever handle.
It is possible that Doug Thompson was selling Mark's chasers at SWAT.
I have the 18 tpi tool from Mark, but I haven't had time to test drive it yet.
Ed
Re: Thread Chasers
Re: Thread Chasers
Allen Neighbors
>A gentleman named Neil MacKay, of Sidney Australia, is making some thread chasers that are different than the pair you can get in the usa. My MacKay thread chaser is much easier to use than the ones I bought at SWAT last year.
One tool makes both male and female threads. You approach each, male and female by having the toolrest sitting across the ways, which for me, is easier.
Of course, postage may be a little more, but the tool is awesome.
This isn't the best photo of it, but it's the only one I can find.
Re: Thread Chasers
Steven Antonucci
I saw Michael Mocho uses one
steve antonucci
>Michael was at Water Gap Woodturners a few weeks ago, and he had one. Nice job with only one piece of steel...
I tried making one with like the one pictured from Australia by grinding a bolt. I'd bet it could be done if you had access to a machine shop and a good steel bolt. The cheap ones are too soft.
Steve
Re: Thread Chasers
Re: Mark St Leger is producing ...
Doug Thompson near Cleveland
>Mark StLeger is selling a 16 and 20 thread chaser, I sold them at SWAT for Mark. It's a handle with a single piece of steel that is reverseable, one end is for interior threads and the other exterior threads. Who ever machined the steel did a nice job and Mark turned the handle. The price was $70 for each size.
Re: Thread Chasers
Re: Thread Chasers *LINK*
Fred Holder
>I have a lot of thread chasers. Those made by Crown, Robert Sorby, Ray Iles, Ernie Newman, and a wide range of old surplus chasers I purchased from a company in England about 10 or 15 years ago.
Several years ago, I was also introduced to a cheap home made chaser by Canadian, Bruce Campbell. He had watched my demo at the 1998 AAW symposium in Tacoma, Washington, but said that he was too cheap to spend the money for a manufactured set of thread chasers. He made his first one from a 3/8 inch bolt that was long enough to cut off the head and install a handle. I tried this also, see attached photograph below. He then ground away the threaded end about 1/2 of the way so that you had an inside and outside chaser on one tool. Of course, the soft bolt didn't hold an edge very long. So he took an old tap and ground away half of it and put on a drill extension shaft to make a nice chaser that had both inside and outside chasers in one tool.
Of all of the chasers I've used, the ones produced by Ray Iles in England seem to work best and fit my hand extremely well. Tools for Working Wood in Brooklyn, New york imports these chasers. I believe they are selling in the $80 to $90 range for a three piece set: inside, outside, and recess cutter.
I've also made chasers from the inserts for pipe threading rigs. I soldered one to the end of a piece of steel and another to the side of a piece of steel. Welding would have been better and more permanent, but at the time I didn't have any welding equipment and I wanted to use it right then. A friend of mine in Australia, Ernie Newman, makes thread chasers and sells them using pipe dies that he has welded to a steel shaft. Ernie gave me a set when we visited him in September 2006. They work very well.
More Woodturning Website
Re: Thread Chasers
Doug is correct, the chasers are ...
>16 tpi and 20 tpi. And contrary to my earlier statement, I have the 20 tpi chasers that Mark made.
Ed
