Peppermill Mechanisims
Ray Binnicker
>I'm going to try my hand at a couple peppermills. Looking through some of the catalogs I see 3 or 4 different types of mechanisms listed. Thought I would ask for some feedback here on which, if any, were a favorite, and, why?
TIA
Ray Binnicker
Re: Peppermill Mechanisims
>Ray,
There was a short thread yesterday (Tue) named "pepper mills" you might read. I love the crushgrind mechanisms - they are made of ceramic and feel smoother in operation. I've used both the shaft and shaftless and prefer those with the shaft.
RonZ
>I like the Crush Grind from Belgium. It's easy to use and lets you be flexible in your design. For instance my wine bottle pepper grinder that was on display at the Wharton Esherick Museum. It also does a great job grinding pepper.
Rasmus
>crush grind is accually danish
Jesper, Denmark
Re: Det er godt, Rasmus......
Jesper, Denmark
>Sig noget til dem :)
Is that from Denmark, WI or Denmark IA
Bruce McElhaney, Spring Lake, Michigan
>I've always used the traditional, Chef Specialities, Stainless Steel Mechanisms. It is my understanding that Crushgrind requires unusual size boring bits and also require the mechanisms to be epoxied into the the mill. That seems like a pain compared to the traditional units. Can anyone address that?
Ken
>OK I plan on making some this yr and was wondering what is the best place to get them at the best price.They wouldn't have to be the best,but would have to be decent ones.I just want to put some nice products out there for folks that either can't afford,or just don't want to spend the big bucks on them,but just want something that they will use every day.
Thanks ken
RonZ
>Sorry, you should tell Craft Supplies because that is what they say, my bad.
Re: Peppermill Mechanisims *LINK*
Tony - Memphis
>Mr. Beall at Beall Tool has addressed that in his book. I don't feel like it would be fair to divulge the secret (the book is only $7.95 I think). I bought the book and when I saw it, I had one of those head slap "why didn't I think of that moments."
I haven't tried it yet, but I have a mechanisim to try. I like that you don't have to have a hole in the top for the nut/adjuster.
Tony
Beall Tool Book on Pepper Grinders
Bruce,
Although the instructions specify metric measurements, I used standard US forstner bits. The Woodcraft instructions (available on the web) show recommended sizes in inches as well as millimeters. I do recal turning some part or other to fit but can't remember the details. The instructions call for a turned notch which is grabbed by prongs on the mechanism. Some people evidently cut off these prongs, omit the notches, and glue the mechanism in place. I didn't glue but cut the notches instead, not by turning but with a Dremel.
I had this note from someone in my files:
I just finished my first pepper mill. It came out real nice.
Not much to the kit, but it's the best and smoothest grinder mechanism I have ever used. A little pricey, but for a ceramic grinder the price is reasonable.
I did not have to glue anything. On the cap I used a 7/8" Forstener bit and took a fine cut with a small scraper and sanded until the top ribs press fit. I did remove the two lock tab points though.
I used a 1" diameter bit on the through hole in the base instead of the 1 1/16" bit called for in the instructions. I sanded to get a nice fit on the part of the cap that enters the top of the base. The measurement of that lower boss is only 1.02" so it doesn't take much to get slip fit that's not sloppy which it would be with 1 1/16".
I used a 1 5/8" bit instead of the 1 3/4" bit called for for the mechanism body and took off the catch points and snaded very little off the 6 ribs to achieve a solid press fit. Could have probably scraped and sanded the 1 1/2" hole instead, but this way was easier.
A bit extension is a must. A nice set of 1/2" to 2 1/2" Forstener bits is real handy, but you can get just the ones you need. The set is a better deal.
Sorry, I didn't make a note as to where I found this.
The instructions on the Woodcraft site:
http://www2.woodcraft.com/PDF/77c14.pdf
http://www2.woodcraft.com/PDF/77c15.pdf
At the risk of excessive redundancy (I've posted this before) the picture below is of the first I made (cocobolo and dogwood) and it was pretty easy.
Rasmus
>yep s� kan de l�re det...
That would be the small contry denmark sitting ontop of germany ...
>John, thanks for the info. I've got a couple of Crushgrind mechanisms in the shop er, "Studio" ;-) that have been sitting around for a while. One of these day I'll have to try them out. Guess I'm too comfortable with the traditional mechanisms. Like your peppermills - especially the Cocobolo mill. Beautiful design. . .
>Tony, I understand and respect your reservation in giving away copywrited secrets. However I seriously doubt there are any "secrets" when it comes to turning peppermills and their mechanisms. It's my understanding that this site is all about sharing information and I personally don't feel it necessary to buy a entire book just to get one basic tip from it. I'm sure I can figure it out, or get some help from others.
>>...Like your peppermills - especially the Cocobolo mill. Beautiful design. . .
Why thank you. After I gave the cocobolo mill to my wife she wanted a salt grinder for the kitchen. As she is easily the best cook in the Southeastern US, she gets what she wants. I picked dogwood for the second one to eliminate any confusion on the contents. (And I love turning dogwood!)
Dogwood is quite close to cocobolo in density so they both feel about the same. It actually looks better than that photo since I blew the highlights in the shot. The photo below may show the true color a bit better.
>when I first saw this piece I thought it was hard maple. I've never turned dogwood - Don't even know where to get it. If it turns like Cocobolo, I want some. Understand is is a great wood for chasing threads?
dogwood
>Bruce,
Dogwood is one of my favorites to turn and carve since it is so fine grained and dense - it will take fine detail as well as clean burning, texturing, etc. It is very strong - it was used for clubs, mauls, and wedges for splitting wood. Also, small diameters are sought for legs and stretchers for rustic furniture. It shrinks and warps and cracks like crazy - a round section of log left to dry can easily open a 20 degree split from the outside to the pith.
Dogwood was traditionally used for parts on spinning wheels and looms since unlike some woods, the more it is used the smoother it gets.
Dogwood is usually a creamy white, often with a pinkish cast, sometimes with wonderful pink streaks. The larger pieces often have dark brown in the center. I cut some I haven't seen before - it has mildly striped grain. Some wood is a light brown all over.
The picture below may show the relative color better - the bell in the center rear is dogwood, next to holly. I think it looks great along with bloodwood - the two complement each other.
The woods on our property are full of dogwoods. The trees often die off before they get very large and make great firewood. I occasionally get a fair-sized dogwood logs - I took one down recently when cutting a road for my new barn and prepared a bunch of turning squares. I once cut a 1"x12" board from a tree from a neighbor's yard - it was unusually big!
I've sold, traded, and given away quite a bit but I still have some. I'd be glad to send you a few pieces dogwood if you'd like to try it - most pieces are cut for small spindle turning and are still green. (Smaller pieces are more likely to survive when drying!) I also have bradford pear which is another very light colored wood, fine-grained and dense. I could throw in a piece of sassafras or sweetgum or figured red cedar.
Got any interesting wood for trade by return box? :)
Re: JKJ-this post reminded me .....
Jamie Donaldson
>... that I looked thru my wood stash and don't have any more English Walnut as we swapped at Folk School recently.
Re: dogwood
>John, I believe I have a bit of Cocobolo, Bocote, Kingwood? South American type Rosewood, Holly and a few others you may be interested in. Also have some interesting 4/4, 5/4 boards for glue ups and what not, including some nice Ironwood boards. Will have to check my turning lumber bin to make sure.
Bruce
Re: dogwood
>I'll send you an email at the address listed. JKJ
