reverse chucking
reverse chucking
reverse chucking
clay rose
>how does everyone reverse chuck their natural edge and hollow form work?
Re: reverse chucking
Dick Hines
Dick Hines
>On natural edge bowls I put a wad of paper towels on the face of the chuck and bring the tail stock up to hold the bowl.
Woodturners supply sell a thing they call a woodchucker mandrel that fit in the opening of a hollow from. Being the cheep person that I am I made one. This will hold the hollow from so you can finish off the bottom.
>For natural edge bowls I use a rubber sink stopper over my chuck and then bring the tailstock up to hold the bowl in place.
John Veerkamp, Western Mo
>I've done similar things that John & Dick mentioned , but I also sometimes make a jam chuck. I bring up the tail stock untill ready to finish the last bit. I tape the piece on to the jam chuck if necessary to do the final bit with the tail stock removed. I use cheap vinyl electricians tape. It works great and leaves no residue.John
Texian
>For hf's I usually turn a jam chuck (from a scrap piece held in the scroll chuck) to a close fit into the top opening of the hf. Align and support the bottom with modest pressure from the tailstock point, and motor gently to clean up and shape the bottom, leaving only a small nub under the tailstock point. Remove the nub with handtool of choice and sand.
Bill Howatt
>For bowls I just use a vacuum drum chuck and vacuum if possible. If vacuum isn't possible, then I bring up the tailstock in the usual fashion and carve/sand any remaining nub.
Bill
Re: reverse chucking *LINK*
Fred Holder
>My technique for reverse turning natural edge bowls is the vacuum chuck. I have the Oneway aluminum cups in three sizes which work very well on most natural edge bowls.
For hollow forms, I purchased one of the devices that San Diego Woodturners were selling several years ago. I don't know if any of them are still available. Mine is illustrated below. It fits into the Morse Taper of the headstock and the tailstock holds the hollow form against the sanding disk holder on the end. The advantage of this device is that the only pressure is against the very base of the vessel. The cone simply aligns the vessel with the axis of rotation. Therefore it doesn't matter how thin the walls are there is no danger of damage to them.
More Woodturning Website
davidwalser
>Don Pencil makes and sells something very similar, his Multi-Purpose Jamb Chuck. It's available on his website for about $40.
keith zimmerman, Normal IL
>for hollow forms, I generally use a jamb chuck to align the form, along with the tailstock for stability. I then carve or sand off the nib that remains after turning the foot.
for mini hollow forms, I turn a jam chuck to finish the bottom.
for NE bowls, I use a piece of dense carpet pad on my chuck and again use the tailstock to align the piece.
keithz
Kirsten Kone  *LINK*
Stuart Johnson
Kirsten Kone
Dick Hines
Dick Hines
>This kind of tool puts no pressure on the top of the hollow from. The little black thing on the end rest in the bottom and the tail stock holds everything.
As thin as I turn hollow forms I can't put pressure on the top. If I do it will crush it.
Dick Hines
Dick Hines
>Check out the artical in the AAW journal, WINTER 2007, page 49. The UHMW poly is cheap and east to turn. I bought all the things I needed from McMaster-Carr. For about $40 I got 6 cones for my live center and the hollow form holder.
