End grain cutting board
Wesley Thompson
>I would like some pointers on making a end grain cutting board. More importantly, gluing up. I will use, rock maple & walnut. Any help will be great. Thanks, Wesley
Re: End grain cutting board
>glue up should not be a problem because you will be glueing side grain to side grain which is the strongest way to glue up. Use Tightbond III, Polyuerethane or epoxy to make it water proof.
Wesley Thompson
>What the glue question is, how would you glue the 2x2 or so blocks together and keep them straight without movement? Should I just make a jig to keep the parts straight. Or am I going to need to plane after I have finished gluing all together?
>Wesley Since this is a turning board I assumed you would be turning the piece after glue up. Because of this glue up isn't critical. If things slip a little that would be OK as long as the glue joint is solid. The traditional way to do a cutting board is to glue together 2x2 long pieces side by side as wide as your cutting board. Then cut 2" strips off of this glue up which leaves endgrain boards 2x2 as long as your cutting board. Then glue this stack together and you have a cutting board. If you glue them up on a flat surface one side will be flat or nearly so already. Then you would plane this surface.
To do a turned board you may want to add contrasting pieces so you could cut all the blocks 2x2x2. Glues have a tack range meaning that once they are together and reach this tack point they won't slip. For this project I would use a slow tack glue like Polyeurethane or epoxy. Put all the blocks together and then clamp. A little careful adjustment as you clamp the groups and it would all go together correctly.
Hot glue this to a waste block and true up one side on the lathe. Then reverse it and do the same. Cloth backed carpet tape would also hold it to the waste block.
>I meant to add that you could easily build an L shaped jig to help align the parts and aid in clamping. Coat the contact surfaces of the jig with floor wax so it won't stick to the cutting board during glue up. A couple of other boards to go on the other side would also help the clamping and reduce the number of clamps needed.
Don wilcut
>What did you say?
It's easy
>You need the long straws up so you place the long straws sideways. Then you glue the longstraws together sideways and cut off pieces so you can glue the long straws together to make the short straws up and this makes short straws into long straws. Then you glue these to more long straws with the shorts straws up and there you are. Plain as the nose on my face but then I'm short sighted and have a long nose.
Re: It's easy
Don wilcut
>Thanks John. Now I get it.
Dennis Barley
>I'm still not clear if you intend to turn the glued up blank on the lathe, but here's a link to a very good tutorial that might assist you:
http://lumberjocks.com/jocks/dewoodwork/blog/2597.
Dennis
robo hippy
>Personally, I wouldn't use the Walnut. Nice color, but an open grained wood. I would use cherry for a contrasting wood, or just the maple. Beech is another wood that would work well here.
robo hippy
Thad
>I can bring mine back up when we come for reference, if you can hold off another few days.
I would not recommend gluing up the way I did, but can show you what I mean when we get there.
