Re: collets and collet chucks
Danny Wells
>Keith,
All collets have a very small tolerance for the sizes that they will hold. I recently purchased the Beall system and also have the system from Woodcraft that fits into the morse taper. Both systems only have about 1/32 or less tolerance for what they will hold.
So I don't think changing your system will solve your problem. I would suggest you try turning your tenon to a more precisely measured size before spending the extra bucks.
I haven't had any problems with either system by hand tightening, if the tenon is properly sized, but if its too small, you can't tighten enough to hold even with the spanner.
