>I have a Delta/Homecraft scroll saw that has been in my shop for many years, but I've never used it. It's complete, and like new except there's no motor. I would like information on pulley sizes, and what rpm's these machines typically operate at. Thanks, Keith
>Keith, I have three scrollsaws and all are variable speed, I can't tell you pully sizes etc, but I know you need to be able to adjust your speeds. Cherry burns real bad if your speed is to fast or if you force the cut 800 to 1200 is the typical speed range I cut in. Most saws(varible) cut in the 400 to 2000 strokes. All I ever used were hardwoods and the finish was either tung oil or danish oil, just put the piece in a tray of oil and let it soak for 5 or 10 minutes drain and wipe off to dry a little then buff it with a cloth. Getting back to pully's etc; I forgot to mention that most regular saws are varible speed but you have to change the belt on the step pullys like you would on a lathe to change speeds. Take Care, DonL
and clicked on "parts" I think, memory not good this early.
Anyway, It took me to site called "servinet" after clicking on links
on the site. Had to put "scroll saw" in the search block but finally ended up with a list of scroll saw model numbers. Homecraft in search block didn't go anywhere.
Point is, when I'm looking for something like this I try to find a parts list for it.
You may have better luck searching as you know the model number.
If you give model number I'll gladly do some looking for you.
>Thanks, guys. I went to the OWW site, old woodworking machinery. I found the owners manual for the machine, c. 1952. According to the manual the tool came without a motor or pulley, but the manual gives details of what motor/pulley combo to use. 3" pulley w/ 1725 motor. I believe this machine has never been used...as new. thanks again, Keith
