ADVERTISE HERE - FREE TRIAL
sanding sealer vs sanding sealer
>I have two Mylands products on my shelf: Lacacote Sanding Sealer and Cellulose Sanding Sealer.
I was under the impression that the cellulose product was lacquer-based; the only difference I see on the label is it 'contains toluene' and a health hazard warning, both of which are missing on the Lacacote product. I've been using the cellulose product for some time but have not yet opened the Lacacote.
The information on the labels is otherwise of no help. I can't find an MSDS for either.
Does anyone know the compositions and reason to use one sanding sealer over another? Or is there a different product one can recommend?
Re: sanding sealer vs sanding sealer
jwoodwright
>John, Found this info. Sounds like Lacacote is Shellac based and similar to Hut Crystal Coat. Hope this helps. John K.
Cellulose Sanding Sealer has been sprayed onto reproduction furniture for years as a sealer prior to applications of Cellulose Lacquer.
It is also effective as a quick drying clear sealer prior to applications of High Build Friction Polish and Melamine Lacquer. It can also be used in conjunction with clear wax polish to give a quick-dry low sheen, water resistant finish. Apply Cellulose Sanding Sealer whilst the lathe is stationary with a rag or brush.
Lacacote Wood Sanding Sealer
Lacacote or Shellac Sanding Sealer has been used by furniture finishers and joiners for many years as a quick drying, natural looking, general purpose coating that enhances the natural appearance of most timbers.
Before High Build Friction Polish, Shellac Sealer was used in conjunction with clear wax polish as a low sheen, quick drying finish, usually applied stationary to the turned item with a brush or cloth. Two to three coats is sufficient, slightly cut back in between with steel wool, and finished with clear wax polish. Lacacote is used by many as a sealer prior to the application of High Build Friction Polish, again applied stationary, one or two coats then cut back and apply High Build.
mpax356
>Ok, everyone probably already knew this. I bought a can of Mylands Cellulose Sanding Sealer several months ago and was frutrateded because it did not come with any instructions on paper or on the back of the can. One day when I was looking at the back of the can I realized that the large label on the back slightly overlapped another label. I wonered what what behind it and carefully peeled of the top label and low and behold they had a complete set of instructions hidden there!
Mike Jones, Redding, CA
>John, I used the Lacacote a long time ago...so long that I can't remember why I didn't buy a second jug...so I can't help much with that. Mylands cellulose sanding sealer is an excellent product, and was my favorite for several years.
Now-a-days, I use Deft sanding sealer and shellac sanding sealer by Zinzer. Deft is probably as good as Mylands, but is cheaper and available just about anywhere that paint products are sold. The "Bull's Eye" shellac sealer is my choice when working with high moisture content wood, especially for "sealing-as-you-go" thinwall turning.
Ric Taylor
Ric Taylor
>John,
I use the cellulose sanding sealer frequently, and I thin it 50/50 with lacquer thinner. It works great and dries quickly.
I use a coat of it between each grit of sanding from 180 through 320, and sometimes 400. Sometimes that is my only finish, because buffing with the Bealle system produces a nice glass-smooth semigloss finish.
I don't know about the other sealer, I've never used it.
I hope this helps,
Ric
