>Has anybody used inlace? Still on the hunt for a substance to use for inlaying stone powder. Two questions: Is it food safe when dry and at what temperature does it start to soften? well, three questions actually, also whe dry, does it flex slightly to move with the wood and does it shink or discolor over time? That's four actually. Thanks for any info anybody mave have.
Is it food safe when dry It's plastic, it's as food safe as your plastic cereal bowl.
what temperature does it start to soften? I'm not sure on this one. I wouldn't put it in the oven but I know it will handle hot water. Not sure about boiling water. That temperature would probably soften it.
when dry, does it flex slightly to move with the wood Yes but I don't know how much. I've used it in hand mirrors where you have a moderate amount of wood movement and haven't had any problems.
does discolor over time? Probably, but I've seen my clear Inlace mirrors after 5 years and they still look good.
By the way the best place I've found to buy it is from the link below.
