Skew Grinding Jig
Skew Grinding Jig
Skew Grinding Jig
>Hello,
This should be under the Thompson skew post below, but is old, so I am putting up here.
John K Jordan and Robert Davis:
Here is a crude sketch of the top view and side views; I could not find the actual jig. It was to work in conjunction with the Lee Valley sharpening jig, but if should work with any tilting table with a slot on it. It is just a few scraps of wood held with CA glue.
I started with a rectangle of 3/8" plywood about 5 1/2" x 2 1/2", to this on the bottom side, a runner that fits snug on the slot was glued; on the topside, 2 scraps as shown on the drawing, to make the 20 degree angle on the skew tip. That's it. The bottom gap of the side blocks should be wide enough to accommodate your wider skew.
To sharpen, you put the skew against one side and make the pass on the grinding wheel, then flip the skew and repeat procedure on the other side.
As you can see, it is simple to make and use, hope it helps somebody to get started, then learn to do it by hand.
Take care
Jorge
Re: Skew Grinding Jig
>Here is my skew grinding jig. On my jig I milled a slot in the Oneway flat grinding jig table. You could just as easily put a lip on the front of the jig to ride against the Woverine jig. I have one of these for my Thompson skew and my Oval skew. I sharpen all the others by hand.
robert davis
>never sharpen by hand when you can use a jig
robert davis
>i use the veritas jig to grind a skew.thompson has adifferent angle. inever grind after initial one use diamond hone..thompson angle is more accute than any of my other six skews.
Milled a slot in your Wolverine?!
Dominic in Buck's County PA
>John,
THAT is a great idea! Heck, Oneway should have done that LONG ago. It sure makes the jig more user friendly.
Dominic
>I was thinking of making such a slot. Is there a standard size for grinding wheel jig slots?
Re: Milled a slot in your Wolverine?!
>I agree. I got the idea from one of the other jigs. I don't remember who it was. I made my first jigs with a lip on the front that rode on front side of the flat jig. The only problem with this is it would try to rock on you if you didn't keep the pressure just right.
>John I made mine some odd size and then had to file the aluminum to fit. That was dumb. When I did it for friend I milled the slots to fit 1/2" aluminum flat stock that I buy at tractor supply. I mill them just a hair deeper than 1/8" so there is clearance.
George Van
>John, could this be safely milled with a router and carbide bit?
Brian Hahn in SW Wisconsin
>I wouldn't use a router - the bit speed is way to fast for cutting metal.
I would do it on the table saw with a carbide toothed blade, although an old steel blade would work as well. I'd make multiple shallow passes. I've cut aluminum more than once with my table saw.
>The Oneway grinding jig table I have is made of steel.
After looking at it again, it is so thin I may make a slotted overlay for it instead of milling a slot.
>I accidentally cut some mild steel with a 16-tooth carbide rip blade. Lots of sparks - not good with all that saw dust laying inside the saw. Both the table saw and the blade survived, and they still are in use.
George Van
>I will check mine with a magnet John. Thanks for the warning!
GalenV
>I was going to update my wooden versions of the Oneway Wolverine grinding jigs with the real thing. Have the Varigrind portion. John Lucus if you were able to mill a slot and John Jordan says his table is too thin is there two versions of the table (like old and new)? Should I look out for the heavier one? If the table is too thin could I just tap to mount a bar when needed and cut the groove in the wood skew jig. Seems I could extend the bar past the table if more horizontal movement needed and still stabilize the jig. Milling the slot sounds iffy. Comments?
Couple of Questions...
Wally Dickerman in Arizona
>Everyone seems to dismiss the Wolverine skew sharpening jig. What is wrong with it?
Why wouldn't it be considered a dangerous practice to be cutting even mild steel with a table saw?
Wally
Re: My opinion....
Russ Fairfield
>The Oneway skew jig is a wonderful tool IF you want to make a straight edge with a flat bevel. It does that for you on a conventional grinder, without having to use a disc sander or the side of the grinding wheel.
Most woodturners prefer a curved edge with a concave bevel. I suspect it is some combination of it being easier to grind, they have never used anything else, and that Richard Raffan and Alan Laser do it that way.
It is a dangerous practice to cut ANY metal on a table saw. Construction workers and fab shops have cut aluminum on table saws for years. They also have a lot of injuries from flying bits of carbide and metal. If you think a "kickback" with a piece of wood is dangerous, you ain't seen nothing yet.
>The Oneway tool rest is thin but it's thick enough to mill a 1/8" slot. It is steel. If you really need a slot I would mount some hardboard on the oneway table with the aluminum as a filler. Then just remove the aluminum and mount it to wood to make your sliding table.
The sliding table is really nice. It allows you to perfectly grind a square scraper, or if you put a tapered guide you can grind the John Jordan scraper or skews.
>A router is way to fast. If you used a speed controller it would slow down but then it wouldn't have enough power.
I've done this sort of thing with a hacksaw, cold chisel and file but it's really slow going.
Re: My opinion....
>I went to my homemade jig from the Oneway because you can't control the rotation of the tool. After you grind it many times it's very easy to end up with a bevel that's wider on one side than the other, or if you look at it from the end the cutting edge runs an an angle across the tool. This isn't a big deal in actual use because I used it for years this way before gettting back to a true center line. I find grinding this tool much harder to maintain than a gouge because you have to remove it to see where you've messed up and then place the backside back down on the wheel and do it again. This removes too much metal.
My jig solves that problem but as you say you can't do the curved skews. I wouldn't be hard to make a jig for a curved skew if you want a continuous radius. One like Alan Lacer does is harder to jig.
Re: My opinion....
>Thanks Russ. I personally like the grind I get when using my Wolverine jig. I don't use a skew often enough to have encountered the problem that John mentions.
If anyone was injured when cutting metal on a table saw it would probably void any insurance.
Wally
GalenV
>Thanks for your comments.
I found when I made my own jig like the Oneway skew grinding attachment the offset pockets did not match the skew end cross angle when laid on the grinder,so I know their offset does not fit all skews! The sliding skew jig looked the best idea and you can make a lot of jigs easily for different skew end angles.
Heck maybe I just need to cut a dado across my wood plateform and spend the money on another lathe tool rather than steel jigs.
At least this topic made me think it out.
Re: My opinion....
>I made the mistake of cutting stone on the table saw once. I won't do that again. It was safe enough but threw black dust all over the entire shop even though I had the dust collector on and a shop vac right beside the cut line.
Don't Cut Metal!
>As Russ points out it is dangerous.
I don't have the Wolverine, so I can not speak about it, but for a sharpening jig, just glue aluminum to the flat thin plate and you have the slot.
$0.02
Jorge
I looked at it again with calipers in hand - it's a little thicker than I thought, .25", perhaps I was fooled by the beveled edge. So GalenV, it looks like there is probably only one version and you could mill a shallow slot without weakening it too much. Too bad they didn't make it with a slot like other jigs.
I also don't like their skew sharpening attachment and wish I'd spent the money on a pancake breakfast instead. Maybe it will be good for something else. In one book Darlow shows how he converted his to a sliding support for the lower end of a long handle.
Thanks--John L & John K
GalenV
>Guess if I go ahead and buy I better do fast if I want a slot milled.
My "free" shop services will be gone shortly.
The Company I retired from after 39 years, Siemens has finally run it into the ground. Manufacturing shop will close Jan. 2 2009 and a good share of Sales, Purchasing, Engineeering, and Services will go as well. Entire site will be abandon in Ames, IA and move small office to "temporary" location. About 170 people now and maybe 40 will remain till who knows when. Not a very merry years end for a lot of old friends. As bad as it is cannot blame the economy for the end.
Original General Filter Company started in 1935. Guess it is good the original founders are no longer around to see this end.
Sorry for long story just visited with my old group today.
Galen
