Sanding pad / Roloc
Sanding pad / Roloc
Sanding pad / Roloc
Guy
>OK, I have used up the last of my 2 inch sanding pads that I attach to a drill. The glue that holds the velcro melts and then it isn't fun anymore. I have tried different brands and my home-made ones last as long or longer. I am considering just using the Roloc sanding discs but I think they may not be flexible enough. Maybe those Scotch-brite pads that go on the Roloc will work. Any suggestions because I do like power sanding but it is getting frustrating and I may have to go back to pure hand sanding. Any opinions, links, etc are definitely welcome. Thank you...
Re: Sanding pad / Roloc
Hello, Guy.
Allen Neighbors
>I use mainly homemade inertia sanders, but I do power sand once in a while. I use a Sioux angle drill, and Vince's blue disks. I never have any problems with them.
I believe that if you're melting things loose, you're using too much pressure and speed that causes too much heat. Use less pressure and less lathe speed. Give it a try and see if it helps.
Vince Welch
>Hi Guy,
Free feel to contact me if you would like sample of my discs. ALso I have scuff bright discs as well. Vince
www.woodnwonders@excite.com
robo hippy
>Guy,
Do check out Vince, if for no other reason, than to read what he says about sanding.
If you are melting the hooks off the pads, then heat is the problem. The easyiest way to cut down the heat is to turn down the speed on both the lathe and the drill. My bowls are warped, and I can't sand above about 25 rpm. I now have a piece of 1/4 inch cork under the trigger of my drill, and no more heat problems. I was worried that it would increase sanding time, and if anything, it works better. I also found out that it increases the life of the bearings in my drill. I normally get 300 plus bowls from a set of bearings. Since turning the speed down, I got 400 plus. I am on the second set of bearings now, and am counting to see if I get the same results.
As far as the power lock discs, I just can't bring myself to spend that kind of price per disc (80 t0 90 cents per 3 inch disc I think). They don't last any longer than any other disc out there.
My prefered discs are from Vince. His outlast anything else out there that I have tried about 2 to 1, with the exception of the green ceramic discs. Here the durability is about the same, but at double or more the cost. I haven't tried the purple ceramic discs from 3M, but would imagine them to be similar. The down side to them for me is they are only available in sticky discs, not hook and loop. For me, this would mean an interface pad for each grit. The cheap sticky discs, you don't care about, use it once and toss it, it is worn out and it won't stick back on anyway. These discs will last for a bowl or 3, and if you peel them off, they will get dust on them, and you will probably have problems with them not sticking. Some time I will have to try them out just to see, but I am waiting to see if they ever come out with hook and loop. If the demand is there, they will make them.
Another advantage with the ceramic and Vinces discs is that they are on a plastic film, not paper or cloth. Very flexable and they don't tear.
robo hippy
George Van
>Guy, if you are melting the glue on the Velcro pads you will really have problems with the Roloc discs. They require very light pressure as they are aggressive. I learned from Bill Neddow that the secret to longevity with the Roloc disc was 6,000 rpm grinders and light, no, very light pressure. The high rpm allows the particles to fracture and thus refresh. If used on a standard drill they last no longer than a standard sanding pad as Robo Hippy suggests. I will have to give Vince�s discs a try, they sound like a good product.
It's hard to beat the ...
Cyril Griesbach
>disks from Vince and his web site is loaded with great sanding information. Give him a call or email with your questions/problems...he's a real nice guy.
Richard Allen
Richard Allen
>For me the keys to getting longevity out of hook&loop mandrills is surface prep before sanding and starting with a coarse enough grit to get the job done.
Tearout is difficult to sand out. I find that a very light cut with a sharp bowl gouge will do a much better job of taking care of tearout than sandpaper.
Small ridges from the gouge are much easier to remove by sanding than small divots are to remove with sandpaper.
It is better to sand with 60 grit for 30 seconds than to sand with 120 grit for 2 minutes. For me the exception to this rule is walnut.
I often find that surface defects don't appear until I am sanding with 320 grit or finer. When a defect shows up for me I drop back 2 to 3 grit sizes (for 320 that would be 120 to 180) to remove the surface defect. and then sand through the grits again.
Brand of sandpaper? I currently like abranet for the coarser grits and abralon for the finer grits. The main key to sandpaper is not how long it will last but how freely you are with discarding used discs.
Grant Wilkinson
>Can someone please post Vince's URL?
Re: Sanding pad / Roloc *LINK*
>Guy, I also ruined a velcro pad before I learned that power sanding, like sanding by hand, should not produce heat. Now when I power sand it is with the driver running very slow and the lathe turning as slow as possible. I do most of my sanding with the lathe turned off, rotating the piece by hand while sanding. I actually do more sanding by hand than with power - if I smooth the surface first with cabinet scrapers often very little sanding is needed.
If you are not using them, get the thin velcro backed foam pad that attaches to the pad that attaches to the drill. Then if you get heavy-handed you don't destroy the expensive part.
Also, Lissi Oland said she uses only the Merit disks and they are so good she is still using some that she bought many years ago. She does big.
http://www.olandcraft.com/Lissi_%C3%98land/Finishing_process_.html
Merit
URL
>Vince, could you post your URL?
the email you post above has problems
Thanks
Jorge
Thanks Van
Re: URL
Vince Welch
>Sorry about that guys.
www.VincesWoodNWonders.com
Vince Welch
>Hi Richard,
I agree with your posting. The only thing I might add is it is important to use a firm back up pad or innerface pad with lower grits say from 60 or 80 grit to 220 or 280 grit. The firm pad is needed to remove any slight undulations in your work piece often you may not see. At that point you may use a soft innerface pad because all you need are light passes with higher grits and slow the lathe speed down with the higher grits.
Vince
Thanks all!!
Guy
>Thank you all for the help. I'll be giving Vince a call. Appreciate the advice !!! :)
