Beginner's question
Beginner's question
Beginner's question
Pat Evans
>I'm trying to make a candle stand base for a hurricane lantern. I hope the attached picture comes thru clear enough to see the detail. I really need advice on how to make the concave cut between the two beads on the edge of the base. Please don't tell me to use a skew chisel. Skews hate me.
Re: Beginner's question
Brad Vietje
Brad Vietje
>Hi Pat,
I would shape the beads and the concave section with a rather "pointy" (long bevel) spindle gouge, and to set the bead off a little, you could cut a tiny flat or groove with a parting tool, or gently scrape in a very small detail with a square-ended scraper, or the long point of a skew on it's side.
Let's see what others would do...
Safe spinning,
Brad Vietje
Newbury, VT
Chuck Engstrom
>I'd certainly agree with Brad's suggestion of a pointy spindle gouge or detail gouge for the half-cove. I generally cut beads with a square bedan, close cousin to a skew, but the spindle gouge will certainly do the same thing.
Good luck with it. Post a photo when your done.
Best--
Chuck Engstrom
Thanks Brad
Pat Evans
>When I tried before, I couldn't get a gouge close enough to the back of the top bead. I didn't realize I had to, or could, turn the gouge nearly vertical and still cut with it.
I'm not clear on where you were suggesting to cut grooves to set off the bead. I are you talking about the top surfaces just inboard of the centerline of each bead diameter?
>I use a spindle gouge. I start with the flute pointing toward the bottom of the cove. On normal cove cutting I would end up with the flute pointing up when I reached the bottom of the cove. If you do that on this cut you will hit the bead with the edge of the gouge and get a catch. In this case I start with the flute pointing toward the bead and end with the flute pointing toward the bead. I you do it this way the lower flute will hit the bead but won't cut and best of all won't get a catch.
