epoxy
epoxy
epoxy
BQ in VT
>what do you people know about using expoxy on a food safe surface? I have a cutting board that I want to do an inlay of stone dust on and I was thinking about using epoxy. Since my inquires about CA glue led me to do some more research and find that it is not suitable, is expoxy not toxic when dry and the blush has been washed off? Thanks for your thoughts.
Re: epoxy
Steven Antonucci
I wouldn't epoxy stone into a cutting board
steve antonucci
>Might look nice, but the stone will dull a knife quickly if accidental contact is made. Also, it would likely chip over time from use.
Steve
Re: epoxy
Jesper, Denmark
Re: I wouldn't epoxy stone into a cutting board
Jesper, Denmark
>But to answer your question, it should be food safe when cured. Most resins are.
Re: epoxy
Re: epoxy
Peter Hyde
>A lot of boat builders use epoxy as a lining to fresh water tanks so i would think it must be pretty safe.
