what went wrong?
GaryG in MD
>BAM! Don't you just hate that sound?
I know what I did -- I'm just not sure why it blew up.
I started with a dried piece of silver maple.
I turned the tenon round and chucked it.
I rounded the outside for a couple of inches up to the rim from the headstock side. As planned, no problems.
I had not yet flattened to top at the rim, so I moved the tool rest around to the tailstock side and started working at the rim with a bowl gouge in the shear scraps mode -- handle very low, flute toward the wood. WHAM! I ripped the whole rim off all the way around.
I don't get it. I thought the proper way to true the rim was a shear scrape. The only thing I can figure is that I got too close to the tip, and the end of the gouge became engaged rather than a wing. I guess that would do it.
So my question is -- am I correct that a shear scrape into the top of the rim is the correct way to true up the rim. I could use a flat scraper flat on the rest, but that seems scarier to me.
Comments and recommendations please. Thanks, Gary
