REAL MILK PAINT
Re, Dust Collector
Re, Dust Collector
Re, Dust Collector
Wesley Thompson
>The size of the shop is 30x40. 2 machines max will be running at any given time. There is no permanent layout at this time. I guess my question is how many drops and how far can a 2hp collector handle running 2 machines at once? Primarily I will want to hook to the lathe,table saw,stand sander and surfacer. The saw and lathe are in permanent locations. The surfacer,stand sander and jointer are on casters. This due to the shop being shared with my truck.
Re: Re, Dust Collector
>Your best references are: Woodshop Dust Control: A Complete Guide to Setting up Your Own System by Sandor Nagyszalanczy and Bill Pentz's website (http://billpentz.com/woodworking/cyclone/index.cfm).
My personal preferences would be to have a 2 hp cyclone. That could power a shop that size quite easily. Do the research before you buy - you might be okay with a less expensive alternative.
BobM
>Another good book is Controlling Dust in the Workshop by Rick Peters. It his plans for building several of the pick-ups which can save a good bit of money. I have a system desinged for using 2 pick-ups at one time and got a 2 hp Onida cyclone. They will design the ductwork for you at no charge. Of course, they want to sell you the ductwork also. BTW, I don't have any financial interest in them, just a satisfied customer.
robo hippy
>I have a 24 by 36 shop. I went with an Oneida system, and as far as I am concerned, they make the best one out there. After consulting with them, I agreed that a 2 hp system was very minimal for this shop size, and 3 hp would be better, especially if I was going to be running 2 machines at a time. If you are going with a 2 hp system in your shop, I would want it to be centrally located, rather than on one end, which would make for shorter runs. They will design a ducting system for you. I did change what they recomended a bit, but stuck with the general perameters.
robo hippy
