On the subject of CA glue...
steve antonucci
>I am one of those guys. No question about it. I might see something I need, and be to darn cheap to buy it until I get a minute to make it.
As turners, we all use CA glue. The tips get clogged and it's a pain. Some folks sell replacement tips. One company sells these things called "Cherry Pickers". They are wooden balls with a needle tip to clear the clog.
Well, duh! I can make that! All I need is a needle and a ball. I have some balls from the craft store, and a package of 40 needles cost the same as one Cherrypicker... did I mention duh?
So I start by drilling a small hole and either CA glue or epoxy the needle into hole. Works perfectly, but I decide to start making better ones. So I glue a bead (from Ebay) and turn a little doodad. Then, a Bead with a bigger doodad (needle is broken in #3, I'll redo). Lastly, a little skew practice and longer finial doodad.
Who said that the needle had to be on a red ball?
Insert into the CA tip, and you are clear to glue...
Steve
P.S. The catalog gets $3/ea for these...plus S&H!
