Spalting question
Spalting question
Spalting question
Sean Troy
>Has anyone ever tried the Miracal Grow solution mixed with a yeast solution? I know about the beer but was wondering if a warm yeast solution would get things off to a better start or just make a mess.
Re: Spalting question
Ron in Drums PA
>Yeast needs sugar to grow.
Try Miracle Grow, Sugar and Yeast. If MG doesn't kill the yeast it may work. I'd be curious to hear the results
Sean Troy
>I'll add sugar and try it on some Hackberry.
Yeast??
>I wouldn't think yeast would give rise much color. I know that some of the other fungi will work better. Have you thought of just taking a soil sample and adding sugar and water?
Re: Yeast??
Dick Coers------WebKitFormBoundaryv54aV+RmMmGf6euZ
>Add some oak leaves or bark from other spalted wood. Spores are what you are looking for. They are everywhere of course, but if you get some "good" (rotten) bark, you will have a head start.
Adrien Coblentz
>speaking from no knowledge at all, yeast, used to make dough rise wouldn't be the same as the fungi. The spalting we see is the fungus's "roots" (hyphae) growing through the wood. When we see a fungus on the outside of a tree, that's just the fruiting body, putting out the spores; the body of the fungus is inside the wood. Yeast might make good beer, but I doubt it would do much for spalting wood.....
Re: Yeast??
Sean Troy
>I was thinking yeast would be the catalyst to grow some funky spores. I like the idea of leaves, dirt and sugar. Thats about as easy as it gets. Do I wrap it all up in a plastic bag and check every month or so?
Plastic can work
>First - a caveat - I was not really trying for spalting. I was trying to keep the wood "green".
Garbage bags - keeps the wood moist - yes you will get fungal development, especially in the outer layers. Does it work - sure.
Moist pile of sawdust - I took some pressure treated 4 x 4s and laid them in a rectangle. Put some 4 mil plastic down. Put a layer of sawdust down, put the logs down, covered with damp sawdust. I rived most of the log sections for my spindles and I left one. It spalted quite nicely.
How quick is it? Quite slow - the fungus does have to migrate and color the wood.
davidwalser
>Sean,
Recently (within the last year), one of the woodworking magazines I subscribe to published an article by an academic on how to get wood to spalt. (I tried looking through back issues last night and could not lay my hand on the article, so I don't have a cite for you. Sorry.) IIRC, she recommended gathering fungus (at least two types) off of trees and rotting logs in the forest. Next, you mix the fungus with vermiculite (a common ingredient in potting soil) and place the targeted wood in a plastic container with the damp, but not wet, vermiculite/fungus mixture. The vermiculite/fungus mixture should completely surround the wood. Cover, but don't seal, the plastic containers and store in a dark, warm, place. After a couple of weeks, remove the wood and see what you've got. If you like the amount of spalting, stop the process by allowing the wood to dry. If you want more spalting, return the wood to the plastic container, covered by the vermiculite, and check again in another couple of weeks.
It's important to keep the mixture moist, but not wet. The vermiculite helps with this since it absorbs a lot of water and releases it slowly. It's also important to not seal out the air. Some spalting fungi require air and sealing the containers will inhibit their growth. Other spalting fungi do not need air, but they'll still grow without sealing the containers since these fungi grow inside the wood or on the underside of the wood where it's contract with the forest floor blocks out the air. You can replicate these conditions by just covering the containers without sealing them.
The reason for using more than one type of fungus is that those dark lines we prize so much are the result of the war between the competing fungi. When one fungus detects the presence of an invading species, it will try to wall off "its area" to keep out the intruder. The lines we see are the remains of the battle lines between the two fungi. No battle, no lines. Not absolutely true, since some fungi produce lines without being in competition with other fungi, but that's not the general rule.
The author also recommended putting some sample pieces of wood in with the mix. Since it's difficult to tell how much spalting has occurred without cutting the wood, the sample pieces allow you to accurately check the amount of spalting without cutting into your bowl blank.
Hope this helps. Good luck.
robo hippy
>The article was in Fine Woodworking about 2 or 3 issues ago. Excellent article. It was more about spalting smaller pieces, not whole logs, but can be applied here.
robo hippy
Sean Troy
>Great info, thanks
Dick Hines
Dick Hines
>I have good luck with just sitting the log on end on the concete floor in the shop. I have had poplar, elm maple and BLM spalt just sitting there. Now all the wood was wet. That may have speeded things up a bit.
