is CA glue foodsafe when dry?
BQ in VT
>I am planning on filling some voids with powdered stone and was wondering if CA glue is foodsafe when dry? If CA lue is not appropriate in this application, does anyone know of an alternative? Thanks.
Re: is CA glue foodsafe when dry?
Steven Antonucci
Don't think it's waterproof.
steve antonucci
>I believe it's foodsafe when dry. It's just plastic basically. As far as waterproof I don't know. I would suspect it is at least as waterproof as the wood but it doesn't move very well so if the wood swells and shrinks it might let go. I use 2 part epoxy when I think it's going anywhere near water. Epoxy is somewhat flexible and the wood in a crack won't move much anyway.
Brian Hahn in SW Wisconsin
>CA glue is safe for closing cuts and wounds - hospital ER rooms and EMT's use it.
CA glue can also be used to temporarily hold in a loose filling. (Got that from my doctor.)
Cured CA glue is probably more food-safe than many foods. (Food allergies, lactose intolerance, etc.)
It's different than our CA.
Allen Neighbors
>The CA used in hospitals is somehow different than that we buy for our woodturning use. At least it's cleaner.
I've used it on a cut before, and I know it works, but when something burns like that stuff, it's hard to believe its good for you. :)
Dick Hines
Dick Hines
>Barbara Dill who did a artical on off center turning in American Woodturner does coffie cups and finishes the inside with CA. I think she has been useing one of her cups for qutie a long with out a problem
Re: It's different than our CA.
Barbara Gill, Remlik VA
>Al you are correct. CA for medical used is a different formulation. I use Star bond CA and even though it is not approved for medical use I sometimes will use it to close a small cut. It never has stung but in large quantity it might generate too much heat.
It is waterproof
Curly Smith
>I've used it repair fountain pumps (attaching impeller to shaft) and it does just fine submerged in, and pumping, the chlorinated water.
Steven Antonucci
That's good to know!
steve antonucci
>I've always avoided using it in "waterproof" needed situations because I thought I had heard it wasn't. Just goes to show you that it makes sense to check the things you "know" once in a while, just to make sure that you know them right...
Steve
P.S. I knew that CA was originally developed in Vietnam for a closing wound in the field. Seems pretty obvious that it would be waterproof...
Re: That's good to know!
>>...it makes sense to check the things you "know" once in a while...
Now I have to periodically double check every thing I know or think I know??? Yikes, that would take way too long, 8 minutes, or maybe 10.
The good news is...
>...that as you get older, it takes less time to check everything you know. :=))
Re: Wrong War, wrong reason
Russ Fairfield
>CA was discovered by Tennessee Eastman during WW2 during a research for a clear sealant for aircraft gunsights during WW2.
Steven Antonucci
Dr. Harry Coover, by accident...
steve antonucci
>working for EK on gunsites, as you indicated.
Didn't patent it until 1956!
From Answers.com:
The use of cyanoacrylate glues in medicine was considered fairly early on. Eastman Kodak and Ethicon began studying whether the glues could be used to hold human tissue together after surgery. In 1964, Eastman submitted an application to use cyanoacrylate glues to seal wounds to the United States Food and Drug Administration (FDA). Soon afterward Dr. Harry Coover's glue did find use in Vietnam�reportedly in 1966, cyanoacrylates were tested on-site by a specially trained surgical team, with impressive results. In an interview with Dr. Coover by the Kingsport Times-News, Coover said that the compound demonstrated an excellent capacity to stop bleeding, and during the Vietnam War, he developed disposable cyanoacrylate sprays for use in the battlefield.
� If somebody had a chest wound or open wound that was bleeding, the biggest problem they had was stopping the bleeding so they could get the patient back to the hospital. And the consequence was�many of them bled to death. So the medics used the spray, stopped the bleeding, and were able to get the wounded back to the base hospital. And many, many lives were saved. �
�Dr. Harry Coover
The original Eastman formula was not FDA approved for medical use, however, because of a tendency to cause skin irritation and to generate heat. In 1998 the FDA approved 2-octyl cyanoacrylate for use in closing wounds and surgical incisions. Closure Medical has developed medical cyanoacrylates such as Dermabond, Soothe-N-Seal and Band-Aid Liquid Adhesive Bandage.
Eastman 910 adhesive I believe
Dick Hines
Dick Hines
>My wife use some "New Skin" on a cut I had on my hand. Burned the crap out of me. I told her the next time I cut myself I would just bleed, thank you very much.
