Truing a disk, (Russ Fairfield)
RPE
>Russ and All0,
I tried to make a 19" sanding disk for my lathe (after reading Malcomb's book--he uses a 20" sander that cost over $1000).
Any way I was making mine of MDF. I just could not get the disk to run true. How can you make the disk true?
I want to flatten segmented rings and sand my segments like Malcomb teaches, but if my disk is not flat, I don't think I will get the results I want.
I don't think it was warped MDF, I think it was just variations in the thickness of the MDF.
Is there a way to precisely flatten a large disk like this?
Thanks
RP
Re: Truing a disk, (Russ Fairfield)
bill Crommett
>Russ: just put it on the lathe and sand it with a sanding board. If you make some pencil marks all around then you will be able to tell if the sanding has done its job. That is the way I sand my segments, because my Performax is slightly off.
Texian
>RP,
I used particle board to make a 15-3/4" sanding disc, as I expected it to be stronger and more uniform thickness than MDF. Found sanding discs at the local tool rental place for use on one of their floor sanding machines. About $7 each and no shipping. So I have a 2 hp variable speed sander (the lathe) when needed.
I don't sand segments, but do sand half rings a bit to match them up. If I were sanding individual segments would make just a 12" disc.
>I used a jointed 2x4 with sandpaper glued to it to true up an aluminum disc that I now use as my sander. I marked the high points as checked with a flat ruler and then made sure my sander remove these pencil lines. It took about 15 or 20 minutes to get it flat enough to not pass light passed my ruler.
