Steussy Creations BowlSaw - Bill Kram in AZ *LINK*
Bill Kram
>Ran across this tool for sale:
Steussy Creations BowlSaw From Steussy Creations
Product Description
My BowlSaw is made to saw off the bottom of a "daughter-bowl" created by a deep groove on the inner lip of the "parent-bowl". This not only gives the woodturner two bowls for one, but they are perfectly matching bowls. This tool is 1/10th the cost of coring tools now on the market, and is much simpler to use. It also saves you time and wood. Cost 39.95
Has anyone had experience with this tool? You know what they say about something that looks too good to be true?
>It looks to me like it's purpose is to cut off the bottom of the already cored bowl, ie. to separate it from the coring which doesn't seem necessary to me because the coring tool does this anyway.
Re: Steussy Creations BowlSaw - Bill Kram in AZ *LINK*
>I don't have any experience with it but if I have it figured out correctly it looks like it would do as claimed but I personally don't see the need nor the savings.
My guess on how it works is: you turn a groove in the larger blank & it would have to be bit wider than the shaft of the tool. You then turn off the lathe and insert the tool into botton of that groove. You would have to turn the blade pointing down and slide it into groove then turn on tool and turn it counter clock wise and the blade would begin to cut, you'd have to repeat this several times each time turning the parent by hand.
The tool appears to have a saw blade on end of shaft that is 90 deg to rotating shaft and the blade would be off set from center on the end of the shaft. This would make the blade move left and right sawing while you turn the tool by hand.
I personally don't see much value. You would also be limited by the size blank because of the length of the blade.
Don
Fred Holder
>I am publishing an article by Steussy on his BowlSaw in the November 2008 issue of More Woodturning. I also have one of the tools and have had the opportunity to try it out. It is designed to core smaller bowls that the larger coring tools would not work well to do. So far, I've only cored one small 5 inch bowl with the tool. It is suprisingly easy to use and doesn't seem to be dangerous if used as he describes in the article that he wrote.
It is not suitable for coring large bowls because the saw is not long enough to cut to the center on larger bowls. I believe a bowlsaw for larger bowls would be too unwieldy to use and probably would be "an accident waiting to happen".
If you are turning bowls in the five to maybe six inch size from exotic woods that cost considerable amounts, this tool might save you some money and get one or two additional bowls out of the piece of wood.
If you want to see more on this bowlsaw, go to my web site and select More Woodturning and then select to see a sample copy. Steussy's article is in the sample on the web site.
>So if I thought something like this would work, I might try to make one myself, since it appears to be nothing more than a Sawzall blade solder to a metal rod.
As far as it being a safe tool, it appears to cut from the underside, which means that you'd have the blade being pulled into the cut versus ejected. With the lathe running slowly, it's probably not that bad.
If I was going to make one, I would take a 12" scrap of 1/2" to 5/8" metal rod and file a square notch in it. I would grind the back end of the blade down to fit the notch, then drill the blade to screw through it into the rod. This would allow me to change blades when they break or dull. If it doesn't work, I haven't lost anything (like $40...) except the cost of the Sawzall blade (I'd reclaim the metal rod...).
steve
>Just got one yesterday and will try it out this weekend. My Scots-Irish background groans every time I waste all that wood in the middle of a bowl blank! .....Ron
>Tried it yesterday and it works. Max diameter for the saw is about 6 1/2" and at that it left about 1/2" tenon that was easily broken off with a rubber mallet. This lets you get into coring for $40 instead of $300 plus. I was a little conservative and opened the groove up to about 1" instead of the recommended 5/8" so my cored piece is smaller. This is handheld on the tool rest so it's not like using one of the anchored systems.......Ron
C.) Could you use it to get a larger core from a larger blank?
D.) How do you replace the sawblade in the even that it dulls or breaks?
It's an interesting idea, and I am guessing that it works pretty well because it is held under the centerline and pulled into the rotation vs. being kicked back? I tried something similar a couple of years back, but I was attempting to cut on the top or the piece, and it was impossible...
Steve
>Here's a shot of the inital setup. The tool is inserted in the slot you just cut with the blade down and the teeth facing to the right and below centerline. Start the cut by turning the blank by hand until you get the cut started. Then turn the lathe on slow (500rpm or less). As the cut continues with the lathe on slowly turn the handle counter-clockwise until the piece is cut away or you reach the limit of the blade. By then you will have a small tenon that can easily be broken with a mallet. .....Ron
>Hi--Thought I'd speak for my BowlSaw. I designed the tool to use the wasted center of the smaller 6" bowl blanks. I've made over 40 sets of bowls with the unit and never felt at any time that it was dangerous. The difficult part is getting the groove around the outside of the bowl. And that would depend on the skill of the turner and his tools. The use of the BowlSaw has no risk at all as you simply turn the saw blade in a dragging position on the base of the interior bowl formed by the groove. My position is that you get two bowls for the price of one and they match perfectly. I think that is an attractive result. Thank you. Richard R. Steussy (Steussy Creations)
