Link belt size
Link belt size
Link belt size
Terry in Ottawa
>I installed a narrower link belt on my lathe because the wider belt would rub on the casting when changing from the largest pulley. This intereference made it difficult to change speeds.
Here's a picture of my narrow belt on a pulley and under tension.
Am I OK with this narrower belt?
Re: Link belt size
Re: Link belt size
>It looks to me like the belt is riding on the bottom of the pulley. It appears there is space between the sides of the belt and the pulley. If So, the belt can not possible transfer as much power as it would if it were tight to the sides of groove in the pulley.
Another question might be, Is there enough power to suit you? Does the belt slip? Some people think letting the belt slip sometimes might be a good thing. If you get a humongous catch, the belt might slip and save your bacon.
Re: Link belt size
Re:Terry- I have been using the link.....
Jamie Donaldson
>....belts on my General 160 for many years with no problems.
Re: Link belt size
Re: Link belt size
wilbur
>Link belts and V belts, which the link belts are designed to replace, come in standardized sizes. The vast majority of pulleys and sheaves found on woodworking machinery have an "A" profile, and can take a "B" belt as well. As far as I know, link belts only come in "3L", "A", "B", and "C" profiles, and the ones sold at typical woodworking stores are only the "A" profile. V belts come in these sizes as well.
Step pulleys, at least the ones commonly available at places like Grainger and McMaster-Carr, only take "A" type belts, whether it's a link belt or a regular V belt. Your link belt should have the profile letter(s) printed on it, and if it's "A", you'll be good to go.
Also, if your link belt is 1/2" wide, it's an "A" type link belt. If it's 3/8" wide, it's a "3L" type belt, and would be too small for your step pulleys.
Re: Link belt size
Leo Van Der Loo
Re: Link belt size *LINK*
Leo Van Der Loo
>Hi Terry
If your belt rides the bottom of your pulley you need a wider belt, if it doesn't you can use this width.
What I don't understand is with this belt or the wider one you still have to clear de edge of the pulley to go to the next size pulley, right ?? so how is this one helping with that problem ?? as there's very little difference between the hight of the belts I think ??
Have fun and take care
Leo Van Der Loo
http://homepage.mac.com/l.vanderloo/PhotoAlbum27.html
Re: Link belt size
Re: Link belt size
Terry in Ottawa
>I've gone back and looked at my two belts, the 1/2 inch and the 3/8. It looks the narrow belt is running on the bottom of the pulley as I can see shiny wear marks on the pulley. The 1/2 inch belt is marked "A" but I can't see any "3L" mark on the narrow 3/9 belt.
I have reinstalled the wide belt and will try that for a while.
Here's picture of the interference I get when I try changing pulleys with the wide belt.
Re: Link belt size
Re: Link belt size
Terry in Ottawa
>And here's picture with wide belt installed and under tension.
Re: Link belt size
Re: Link belt size
wilbur
>From your measurements and the pictures, the 1/2" wide link belt is the one you should be using on your lathe.
Have you considered getting a regular V belt to replace the link belt? It's a little bit of a pain to disassemble the headstock spindle to install a regular V belt, but it's really not that hard, and you'll take care of your clearance problem when changing speeds.
Re: Link belt size
Leo Van Der Loo
Leo Van Der Loo
>Hi Terry, yes too bad, but yes you need the wider belt, smoothen the inside of the headstock (file, sandpaper etc.) should help some in sliding the belt over the rim.
There are lower profile link type belts made, though I don't have any places you might get one of the top of my head.
Fenner might have them, but I'm not sure about that, if you find it too much of a hassle you could go back to a regular V'belt, it helps, but there's not much room top or bottom in these lathes, there were some post on rebuilding some older Delta Rockwell lathes in The Canadian Woodworkers forum, you might get some more help/info there maybe.
http://forum.canadianwoodworking.com/
