>I have a nice piece of green "spalted Maple" 4 " SQ. I want to turn it into something right away. I want to speed up the drying process; can I get the oven hot; turn it off; put the blank in the oven for several nights and get it dry enough to turn; or will it dry too fast and split like crazy. I have heard of putting a turned green bowl into something warm to finish the process. Give me your thoughts and ideas PLEASE. I'm just impatient. I read somewhere that you can
>Small pieces can be dried in the microwave but you do risk cracking. Larger pieces like 4x4 are very slow to dry in the microwave. The reason wood cracks is uneven drying. The outside dries and shrinks, the inside is still wet and full size so something has to give. the oven makes this problem worse. The microwave tends to heat the inside. This can even out the drying process.
I've had pretty good luck drying box blanks but I don't remember drying any larger than 3". My microwave only has high so I put the blank in there for 30 seconds and see how it feels. If it feels hot I let it cool completely and then do another cycle. Eventually it won't feel as hot so I up the time to 1 minute. I let it cool between each cycle. I usually plan to spend the day doing this. I don't know how many cycles to tell you. I simply heat it, pull it out and go do something else. When I think about it I put the wood back in and do it again. I do this pretty much all day, probably 8 to 10 cycles or more. I have a set of scales nearby and I weight it often. When it stops losing weight it's dry. Sometimes if I don't do enough cycles it may run into the next day. I let is sit overnight or longer to pick up moisture from the house so it's more stable.
You still may lose some. Some woods just don't want to be force dried.
>Hi John, I often read of turners who weigh turning blanks to check the drying process . What kind of scales do you use that can record such small differences of weight ? Any brand names ? costs ? E-Mail links?? Thanks ,Tom in S/E Ohio
>I've got a nice scale that either does ounces and pounds (1/8 ounce) or grams and kilograms. Maximum weight is about 10 lbs. You can also try postal scales.
It will dry much quicker if you round and hollow it somewhat first. I generally partial turn then air dry, coating with wax in some circumstances. The microwave works well if you work slowly and don't overheat the wood.
Russ Fairfield wrote a short description here of what he uses to dry turnings and blanks. Link below.
>I was at the flea mkt and picked up a used set of triple beam scales. As a photographer I used to mix all of my own chemistry from scratch. Now I just use the scales for boxes and pen blanks. I use my larger family scales for bowls. I don't trust the small weights so I put a 25lb barbell weight on it an then add the bowl. It seems to work fine this way.
>If you go to Harbor Freight and search for "digital scales", you'll come up with four candidates that range in cost from $20 to $43. Obviously, there are plenty of other vendors. I just went HF to get an idea.
