Peppermill set
HeatherA in AK
>Hello, I made this Salt and Peppermill set for an auction at my children's school. They are walnut, one with a bit of sapwood. I was worried about the first one because I had never made one before, and more worried about the second one that it would match. I have put a couple of coats of Deft on them but would like to put some varnish on top. I have read Russ's finishing secrets (about 20 times) and have a couple of questions. I got the Watco Teak oil finish. In the finishing secrets it does not specify if the varnish over lacquer is applied on or off the lathe or if you could do both. I also bought some Benjamin Moore Alkyd varnish and turpentine. I don't have any teak oil but have some polymerized walnut oil. Can I use this instead? Which one would be best for a peppermill, the Watco Teak oil or the homebrew (if I can use the walnut oil). I have mostly used shellac in the past so don't have much experience with varnish.
Thanks,
Heather
