THE WOODRAT IS BACK!
Need Help Jet Mini Speed Controlt
Ed Larson
>I just purchased a Jet Mini 1014 with speed control. The plastic cover for the control box was broken so I contacted Jet and they sent me a new control box. I had taped the broken box together and the speed control worked fine. I just installed the new box and now the speed control does not work; it's on high speed no matter what the speed control setting. I was very careful in the replacement and do not believed I did any damage to the control circuit board. Need help. Has anyone had this proablem?? Is there a way to reset the system?? I will contact Jet tomorrow and see if they have any ideas. This is a bummer as I'm going to a club demo for a harvest festival on Sat. and now do not have a varialbe speed mini.
Re: Need Help Jet Mini Speed Controlt
GalenV
>Sounds like you reconnected the speed potentiometer incorrectly or the connections to the board whichever end you removed to replace the cover. I hope you recorded how the black , white and blue wires were connected. White wire is shown to the pot center or wiper connection and to the center of three connctions on the board. Looks like the board is not identified by any terminal numbers.
Just a point to try but sounds like it got reconnected so the variable resistance is not used correct.
Galen
