Waterlox
Waterlox
Waterlox
BobM
>I like to use Waterlox finish but, have trouble with it turning to a jell. Does anyone have any suggestions how to keep it from "jelling up"?
Re: Waterlox
Re: Waterlox
Greg Haugen
>Once you understand "how" it happens you can do several things to prolong it. It gells from exposure to oxygen. Remove the oxygen, you prolong it from gelling. These are some thing I've heard and a few that I've tried.
Bloxygen, a commercially available gas that comes in a can that displaces the oxygen from the can.
Glass Marbles-by adding glass marbles to a can as the finish is used lessens the amount of air that is in the can.
Decant it, dump out the can into smaller air tight containers. If something goes bad, it will only be the one container.
Crushable Containers, I think I saw it in Lee Valley, it's a plastic jug that is like the "bendee" straws, as the finish is used the container can be collapsed to lessen the air.
"Wine Bottle Pumps". Dump the finish into a clean empty wine bottle (not like most of us don't have a few "empties" laying around. :-)) Wine shops sell hand pumps that comes with a special cork so that the cork can be stuck in the bottle and the pump will suck the air out of the bottle. Thus preserving the wine/finish. After you're done with it, cork it and suck the air out.
All of these options do "help" in preserving Waterlox, they each have their pros and cons. Hopefully some will "chime" in about their experience.
One note, I do not throw a can until the finish is all gelled. Someone has on their site, "as soon as you see "gel" on the cover the can must be thrown." I even asked Waterlox about this claim and they completely disagreed with it. The cap will have some "gel" on probably after the first or second use. It's just the finish that is on the lid, not the whole can.
Just my 2 cents..
Greg H.
Re: Waterlox
Re: Waterlox
Brian Hahn in SW Wisconsin
>I transfer Waterlox into plastic bottles, usually 2 ounce and 8 ounce bottles. I put the sealed plastic bottles in a Ziploc bag and store them in the freezer. I work from the 2 oz. bottles, refilling them from the 8 oz. bottles as necessary. The 2 oz. bottles only take a few minutes to warm up to room temperature and be ready to use.
The freezer is a great place to store oxygen-reactive finishes. The cold slows down the polymerization reaction rate by several orders of magnitude. (My guess would be by a factor of 10000.) Just make sure that the containers don't leak and use plastic freezer bags as an added precaution.
Re: Waterlox
Re: Waterlox
Greg Haugen
>Brian,
That's one I haven't heard of before. I'll have to give it a try.
Thanks.
Greg H.
Re: Waterlox
Ric Taylor
Re: Waterlox
Ric Taylor
>Bob,
All of these efforts mentioned are really not necessary. The gel is only a layer on the surface. What is below the surface is good as new.
I transfer about 1/4 of the can into a jar with a tight lid. I then use the portion that is in the jar to do my finishing. A layer of gel does form on the top in the jar, and a layer will form inside the can also. That is not a problem. Just use a pipette to stick through the gel layer into the good fluid below, and draw up as much fluid as you need to squirt on to the cloth you will use to apply it to your turning. Or you can squirt it directly on to your turning and spread it around. That is perfectly good waterlox, and I have never seen any problems of any kind. Several people in my club use this method.
When I have used up all of the good fluid in the jar, I just throw away the jar, and pour more waterlox from the can into a fresh jar. I have been using the same can of waterlox for about 18 months now. Waterlox is too expensive to throw away, especially when there is nothing wrong with it.
I bought 200 pipettes on eBay for $1.25 plus shipping. If you want to, you can use each one several times, and they will last for a loooong time.
Ric
Re: Waterlox
Dick Hines
Re: Waterlox
Dick Hines
>I put put a can of Waterlox into baby bottles now I have 8 bottles of hard waterlox. I went back to Watco.
Re: Waterlox
Re: Waterlox
Ian
>I use waterlox all the time, local supplier only carries quarts,
I use a small fine screwdriver to pop on the innerseal when I open a new can. reinsert seal when i close up the can and put cap on tightly and invert the can for a few minutes.
if I loose any of the can do to jelling it only the bottom 1/2 inch.
I tried transfering, marbles and blogen, usually lost at least 1/4 of can.
just what works for me.
IAN
Re: Waterlox
one more...
GaryG in MD
>Bob,
You've had lots of good answers and also seen that not all of them work all the time. It's clearly a crap shoot.
Here's mine -- works for me.
I decant into smaller plastic bottles with ...what to call them... say, "squirt tops" -- kind of like the containers you used to see in restaurants for ketchup and mustard. These come from many sources with snap-on tip covers. The real trick is to store them upside down! The gel forms at the air space on top, but you can squirt out a little or a lot -- whatever you need. Just keep them upside down. I store them in some kind of old can in case they might leak (they haven't). These bottles also tend to suck in to automatically reduce the volume -- but that's not really important.
It's good stuff, but it can be frustrating.
...Gary
Re: Waterlox
Leo Van Der Loo
I use a � L maple syrup bottle, *LINK*
Leo Van Der Loo
>the kind with the ceramic stopper with a rubber ring that you clamp down.
It has a narrow neck also, after dispensing what I need I add clean water till the bottle is full and clamp the top down, it eliminates all air and I can see exactly when the oil will be gone, works a charm for me and others that I know who use it.
Have fun and take care
Leo Van Der Loo
http://homepage.mac.com/l.vanderloo/PhotoAlbum25.html
Re: Waterlox
Yes, don't use it.
GolfSteve in Calgary
>I gave up on Waterlox. I tried the small bottles thing, I tried filling the headspace with propane, I tried eliminating the headspace by topping up the jar with water. Nothing really worked.
My Waterlox would turn completley gelanenous (not just a skin on the surface) overnight. The stuff was expensive, hard to find around here, and the finish I ended up with was no better than Lee Valley's Polymerized Tung Oil (which I love).
No more Waterlox for me.
Re: Waterlox
Re: Waterlox
BobM
>Thanks for all the good tips. I knew I could find help here. What a great website and great group of people!
Re: Waterlox
Re: Waterlox (one more)
Mike Jones, Redding, CA
>Read Russ Fairfield's recipe for making your own "Waterlox". I've been using home brew for just a few months, but I'm having fun toying with slight modifications to the proportions of the three essentials.
I'm getting good results, not losing any product to gelling, and saving lots of money. (Thanks again, Russ!)
Re: Waterlox
Andy DiPietro
Andy DiPietro
>Hi Mike,
Would you please share the link to Russ's Waterlox recipe?
Thanks
Andy D.
Re: Waterlox
Dave L
>I think it is one third turentine
one third tung oil
one third gloss spar varnish
russ gives specific brands but i think any would work. You might want to reseaarch the above, but i think I have it right.
Re: Waterlox
Dave L
>the first one should read turnpentine
Re: Waterlox
Russ's Recipe...
>Andy, the recipe and much, much more...highlight "Articles", click on "Russ's Corner"...all right here on Woodcentral!
Re: Waterlox
Russ's Waterlox recipe...  *LINK*
http://www.woodcentral.com/russ/finish7.shtml
Re: Waterlox
Re: Waterlox
Ed Heuslein
>Bob, here's one that does work. I use the boxed wine containers. Take an empty wine bag, wash it well and let it dry thoroughly (you'll have to remove the spout, but it pulls right off). Then pour your Waterlox into it. Open the spout and slowly remove all air by pushing the finish right up to the spout. Close it. Put the bag back in the box and you're good to go. I just decant a little into a small container when I want to use it. Don't try to put unused back into the bag - it's more trouble than it's worth. You'll soon get a feel for how much you need to do a particular project.
I have a box in the shop right now that I put into the box in Jan. of last year and it's as good as the day I did it.
Feel free to contact me if you have any questions.
Re: Waterlox
Andy DiPietro
Thanks Guys
Andy DiPietro
