tung oil thiner
Hugh Widdup
>I am using Minwax tung oil for most of my finished turnings, it is about 3months old and it is starting to thicken/seperate, is there a thinner I can use to bring this back to a more usable mixture?
Hugh
tung oil thiner
Hugh Widdup
Hugh
Re: tung oil thiner
John Veerkamp, Western Mo
>It's possible that mineral spirits will thin it out some, but if it's started to polimerize it is done for. Time for new.
John
Re: tung oil thiner
Dave Peebles Lyons, Ohio!
>Hi Hugh,
My experience is the same as John. If it starts to thicken, it is gone. Finish is relatively cheap, If it were me, I wouldn't take a chance with a finish that might ruin your work.
Best wishes,
Dave
Re: tung oil thiner
Ken
>I agree,been there tried it.You will end up with a mess as it will not cure right.
Ken
Re: tung oil thiner *LINK*
Leo Van Der Loo
>Hugh tung is not a drying oil, but a polymerizing oil, you cannot thin it after it has polymerized, only 3 months old ????
Next time keep the container closed and full, so the oil doesn't get exposed to air as much, pour water in the container to keep it full, (oil floats on water so the water goes down) HTH
Have fun and take care
Leo Van Der Loo
http://homepage.mac.com/l.vanderloo/PhotoAlbum28.html
For the next time..
>Try putting the quart can in smaller containers (metal or some other barrier container is preferred). The less head space available, the less oxygen can get to the oil.
Bloxygen does work, though it is expensive. Carbon dioxide gas (soda water charger, found in bar supply stores) also works. A somewhat flammable alternative (not recommended) is to layer some propane gas from a unlit torch on top.
I don't really like the water alternative myself.
Once it starts gelling though, it is "toast". Pour it out and let it finish polymerizing.
Re: For the next time..
Dick Hines
>You need to spend more time turning. That way you can use up all of your finish before it goes bad.
Re: tung oil thiner
Hugh Widdup
>I will toss this out and pick up a new can tonight, and find some smaller bottles to decant too....
Dick you are correct, more time turning....but this raises another question......where do you find that?
Thanks the information
Hugh
Re: tung oil thiner
Russ Fairfield
>There is nothing wrong with using the thickening oil as a finish, but it will cure slower. The older it gets, the longer it will take to cure. When it starts getting a rubbery consistency, it will never cure. Adding more thinner will make it easier to apply, but it will do nothing decrease the curing time for an aging oil finish.
The risk is knowing how far gone it really is, and you won't know until after it has been applied to the wood.
