Manual for Woodfast lathe
davidwalser
>All,
I have a Woodfast shortbed lathe (not the one made by Rikon). I don't have the manual that came with it. (I bought it used.) Any suggestions for where I could get a copy of the manual? I'm asking because I assume I'll need it some day. As of today, the lathe's working fine.
Re: Manual for Woodfast lathe
Re: Manual for Woodfast lathe *LINK*
JohnKyler
>This is the non-import version. But most of the info should apply.
John
http://www.woodfast.com.au/pdf/M910.pdf
Re: David-my own Woodfast shorty .....
Jamie Donaldson
>... is still a favorite in the shop,and you will really enjoy your new tool/toy. My Woodfast shorty was my main production machine for many years until I began wanting more power, and that is when the Stubby(Studly!) appeared.
davidwalser
>Thanks, John, but the link is to the brochure, not the manual. I'm looking for information that will help me maintain my lathe. I'd hope the manual might have that kind of information.
davidwalser
>Jamie,
Thanks for the good thoughts. I do like my Woodfast. Someday, I wouldn't mind having a Stubby (or a Robust, Oneway, or...). Right now, the Woodfast will more than do. Before I replace it, I'll be replacing the shop, bandsaw, and just about everything else.
Jim Pugh, Elyria, OH
>David, the older Woodfast lathes were originally imported and sold by Craft Supplies. YOu might check and see if they can be of any assistance. By the way, my turning buddy and I think their 12" tool rest is the best available. Enjoy the lathe.
Dinyar Chavda
>David:
What's your model number?
D
davidwalser
>Dinyar,
The lathe has a 16" swing and I assume it is a model 910. I'll confirm it when I get home from work.
Re: Model is Woodfast M408 I expect.
Jamie Donaldson
Dinyar Chavda
>Let me know. I have a manual for my Woodfast, and it covers many models. If yours is one of them, I'll scan it and e-mail it to you.
JohnKyler
>Hit the trigger too fast.
Sorry. I know that either the long or short bed are basically the same.
I had the short bed and then the long bed, and then ended up with the Powermatic 4224...
I looked again and I no longer can find the manual online.
John
gtwilkins
>Have you tried posting on:
http://www.woodworkforums.ubeaut.com.au/forumdisplay.php?f=8
Maybe one of our upside down mates could help, I think the Woodfast was made in Australia originally if my ailing memory is right.
Trevor
John Peck
>I e-mailed you one earlier today, 10-6-08. Hopefully you received it.
Thank you
David Walser
>I did receive the manual via email. Thank you.
Turns out my Woodfast lathe is model 408S if I'm deciphering things properly. I could not find anything on the lathe itself that indicated the model number, but the specs of the lathe match up with what the manual says is model 408S.
Re: David- I'm curious about what S means?
Jamie Donaldson
davidwalser
>So am I. The manual has a table listing the specifications and included equipment for each model. The 408 and 408S have much in common -- they seem to be based on the same casting. One difference is that the S model came with a hollow tailstock center (allowing you to drill lamps and such). Mine a hollow tailstock center (and the other equipment listed for the S model), so I concluded that it is a 408S. However, the manual appears to be for the non-US version of the lathe (since everything is metric). My model could be completely different and it only has the equipment it does because that's what Craft Supplies added once it arrived in the US.
Re: Mine is a model#M408 purchased .....
Jamie Donaldson
>...from Craft Supply early 1990's and does have the drilled tailstock ram. I believe CS built the bases for the import lathes, and mine has a very substantial steel plate frame under it. Mine is serial #408 27 95 and that might mean it is the 27th built in 1995?
I Suggest...
Wally Dickerman in Arizona
>David, since Craft Supplies was the distributor for the Woodfast lathe, I suggest that you contact them for information.
The community woodshop where I taught classes for a lot of years has 7 Woodfast lathes. Some are longbed and some shortbed. They are about 12 years old. They are a good machine with a few faults. In a community shop they get a lot of use and abuse but they have held up very well. We have recently replaced the spindle bearings and the electrics on all of them.
Wally
Michael Wilkins
>Contact Craft Supplies, suppliers of turning tools and supplies. I also have the Woodfast shortbed lathe, purchased used, without the manual. I contacted them for an inverter problem I had, and they mailed one to me at no charge.
They sold these lathes at one time in the past, but no longer.
