Anybody use
Anybody use
Anybody use
Darryl
>the Triton "Superjaws" or more expensive (as seen on TV) Rockwell "Jawhorse"? Since I broke my hip I have trouble kneeling to cut up logs. I thought I could use one of them to hold a log while I sawed standing upright.
Re: Anybody use
Steven Antonucci
I made a bench
steve antonucci
>I looked at what they were, since I hadn't heard of either, and I would just make a saw bench. Here's mine. It's at least 10 years old, and I still use it all of the time...
Made from leftover scraps.
Steve
Re: Anybody use
Re: Anybody use
Tommy Holmes
>I saw the Jawhorse advertised on TV for the first time this weekend and had the same thought as you did. My thought is with it being all metal (my understanding) that it may not be so so good on the chainsaw blade.
Re: Anybody use
Re: Anybody use
Darryl
>Triton has a video showing its use with the log jaws. They seem to be out of the way. Will handle a log up to I think 12"
Re: Anybody use
Re: Anybody use
davidwalser
>I don't have any experience with the Triton or Rockwell products, which won't prevent me from commenting! In Lyle Jamieson's excellent video, Bowl Basics the Easy Way, he recommends using a Black and Decker Workmate (or one of the many knockoffs) to hold logs for sawing. The Workmate allows you to clamp the log securely. It allows you cut the log into shorter sections -- by extending the part of the log to be cut off out into space. It also allows you to split the log by cutting between the Workmate's jaws/split table.
The nice thing is you can pick up a Workmate at a yard sale or thrift store for next to nothing.
Re: Anybody use
Re: Anybody use
Rich Egan
>I have an upright steel bearing press with a hydraulic ram on it. Clamp your log in there and saw away. It's not going anywhere.
Re: Anybody use
Re: Anybody use
Allen Neighbors
>I have a 30" Sweet Gum Log, standing on end, on an 18"x18"x18" chunk of concrete that has been put into the ground about 8-10". The log is about 16" diameter. I have cut a large "V" in the top end of the log.
I saw standing up. It'll handle any size log I can put on it. Just have to heave them up that high to work, but it is easy when done right.
Re: Anybody use
Re: Anybody use
Texian
>Not mine. It's about 30 years old and still in regular use in the shop. Old wood stand for previous bandsaw is now good for sawing logs.
Re: Anybody use
Re: Anybody use
don lewonczyk
>You won't get my B&D workmate either unless its at my estate sale. I got mine when they first appeared on the market in the early 70's when I was building custom pickup tops in DE, that model was the strongest and best made and I go to alot of yard sales and have never seen one like that. There is alot of the cheap shakey ones out there but nothing I would pickup. I would rather bend over to cut my wood then abuse a good helper by piling on a 75 to 100 pound log on it. I use my log splitter to bust them down the middle(20ton) hydralic and take the 2 halves lay the round sides up and put the sections that I cut to length between them. The rough bark on all three pieces pretty much keep the piece from rotating, my take on skinning the cat. DonL
Re: Anybody use
Leo Van Der Loo
Re: Anybody use
Leo Van Der Loo
>I would NOT recommend holding the log securely between the workmate jaws and split the log in two by sawing it that way.
The log WILL pinch your saw and a kickback is very likely if held that way.
I use a large stump, with the center cut lower to hold the log to be sawn, when cutting through the centers on a crotch I will often hammer a large screwdriver in the stump on both sides of the crotch so it will not move or roll while sawing, has worked well for me for many years already ;-)).
