Chain saw died!
Chain saw died!
Keith Tompkins
Chain saw died!
keith tompkins
>I went to use my saw today, it started fine, but died whenever I pulled the throttle. I traced the problem to the fuel line from the tank to the carb....it had softened and collapsed, resulting in no fuel. This is the first time the saw has let me down. It is a Stihl 028 Super, purchased in 1990. I'll pick up a new fuel line tomorrow if it is in stock. I guess I can't complain, however, The MS 441 Magnum I spotted on the dealer's shelf is looking mighty good!
Re: Chain saw died!
Re: Chain saw died!
>Yes, buy the new saw and send me your old, cast-off, broken trash to dispose of. (I know I have some extra fuel line around here somewhere).
It worries me that the fuel line softened. Do you use any fuel additives? Is there alcohol in the gas you use? (a no-no according to the pros) Is the saw stored where it gets real hot?
Re: Chain saw died!
Re: My old Stihl Farm Boss had ......
Jamie Donaldson
>...the exact same problem several years ago. I don't understand why- it was only about 30 yrs. old?? (;-D)
Re: Chain saw died!
Keith Tompkins
Re: Chain saw died!
keith tompkins
>Hi John, No, I use high-test gas and Stihl oil exclusively. In New York, all fuel, I believe, is 10 percent ethanol, so that may have contributed to the problem. I really don't need a new saw, but it sure is tempting! Wood is my heat source as well as turning material, so my saws earn their keep.
Re: Chain saw died!
Keith Tompkins
keith tompkins
>Jamie, They don't make 'em like they used to!
Re: Chain saw died!
Re: Chain saw died!
Carole Valentine
>I heard that they were going to increase the percentage of ethanol next year. Is that going to kill our saws even faster???
Re: Chain saw died!
Keith Tompkins
Re: Chain saw died!
keith tompkins
>HI Carole, I think the manufacturers will come up with alcohol resistant materials, it does't seem like an insurmountable problem. Remember when lead was removed from gasoline? We were told horror stories, but, in fact engines last longer now than ever...when was the last time anyone you knew needed a valve-job on their vehicle? The hose that failed was a molded piece, curved, with a built-in grommet to prevent fuel leaks. I suspect the material wasn't standard fuel-line material, but failing after 17 years submersed in fuel really isn't so bad.
Re: Chain saw died!
Keith Tompkins
Re: Chain saw died!
keith tompkins
>Update: new hose with tank filter...back in business! Total cost: twenty bucks.
