REAL MILK PAINT
Greame Priddle Type Wood Vaporizer *LINK*
charlie belden in san jose
>You've probably seen a Graeme Priddle piece that has some pyrography / wood burning on it. If you've seen him actually do it you know it's not pyrography - but more like Wood Vaporization - a flash of light, a puff of smoke - repeat - carefully. And he ain't using no itty bitty 1 or 2 amp power source - oh no no no. Think "10 AMP battery charger" - with a little internal reworking.
And if you've seen him demo his not so little beastie you go home thinking "I'm gonna make one of them things!" - visions of vaporizing wood dancing in your head. Then you go home and try to remember all the details he mentioned - and try and figure out how to fill in the stuff he overlooked mentioning. Then the idea get's put on the "Someday I'm Gonna" list.
Well Someday may come a little sooner with the help of Phil Royal's helpful how to in the 07-2008 Silicon Valley Woodturner's newsletter.
Click on the attached link, scroll down to 07-2008.pdf and check it out
charlie b
ps - Phil is also an amateur blacksmith/tool maker and this same newsletter as an article he also wrote on tool making.
DIY Wood Vaporizer Power Supply
Re: Greame Priddle Type Wood Vaporizer *LINK*
Allen Neighbors
>Charlie, thanks for putting the link to the pdf file in here. I've been wanting to make one of these but didn't really understand how. You can't miss with Phil's instructions. Thanks again!!
Re: Graeme Priddle Type Wood Vaporizer *LINK*
charllie belden in san jose
>Found my notes on this thing and have added a page on more details about parts not in Phil's article.
addendum with parts numbers
Thanks Charlie, got it, too. :o)
Allen Neighbors
Molly Winton
>Hey Charlie, Thanks for the added info. A question from a clueless person though: What are the banana plugs for, and where do you get them?
>Thanks Charlie I've been wanting to build one ever since I saw him at the Craft Center. Of course that was this summer and my memory doesn't last that long so this is a good refresher.
>Molly,
I'm not Charlie, but banana plugs are widely used in the electronics test field for patch cords and the like. I have them on power supplies and meters. They are popular since they are very quick to connect/disconnect, have a reasonably contact area, are low noise, low resistance, and will still handle a fair amount of current. Many of the banana connectors sockets you buy to mount on equipment will allow multiple connection methods: you can plug in a banana plug or screw down on a wire or spade connector.
The picture in the wikipedia article shows twin banana plugs on the top of an adapter to couple a BNC signal connector (the bigger connector at the bottom). The spacing you see is fixed to an industry standard. BTW, banana plugs are single conductor connectors unlike phone, phono, mini, BNC, and many other connector types which often connect two or more conductors.
You can buy banana plugs and sockets at Radio Shack, any electronic supply house, or from any of a near infinite list of suppliers who advertise on the internet. If you know an electronics junkie, they can probably give you some from their junk drawer.
http://en.wikipedia.org/wiki/4_mm_plug
Carol - now back in Dubuque, IA
>You can them at Radio Shack, Molly.
But I, too, want to know where they go. I would find it helpful if someone posted a wiring diagram, as I get lost in all the verbage, and am often confused by the terms chosen.
I am a picture person.
Also much was assumed in the article regarding the handpiece. Some more specific info there would be nice as well. And about making burning tips from the nichrome wire.
I know. I know. I don't want much, do I? But I've only ever seen Jen's burning set up and my memory isn't worth much past yesterday.
>Carol,
I opened an old transformer-type (not electronic) 6/12v charger intending to draw a circuit diagram for you but it was so simple I don't think it's necessary. To build as suggested just find the wire inside that comes into the box from the 110v power supply and goes to the switch on the front, snip it in two, and wire the light dimmer inline.
Note that you don't have to put the dimmer inside the box. To keep from opening the battery charger, you could mount the light dimmer in a double plastic box from your borg along with a duplex outlet or a combo switch/pilotlight/110v outlet. Plug the battery charger into the outlet on this box. The switched outlet would let you leave the dimmer at a particular setting and switch the power to the whole thing on/off as needed. (This is real simple to make. I use one of these to control the brooder lamps for baby chicks and have also built them with a transformer inside to make hot-wire styrofoam cutters with nichrome wire.)
The banana plugs are simply to connect your handpiece.
If wiring the thing up into a single nice clean package, I would remove the cables that would normally go to the battery, pull a length inside the case, and wire them instead to a pair of case-mounted banana sockets mounted somewhere on the front of the charger case. Or simply cut the cable somewhere and wire a pair of banana sockets made for cables rather than case mounting. Either way, wire banana plugs to the ends of the wires to the handpiece. It would also work, at least for testing, to just clip the battery terminal clamps to the wires to the handpiece but you would have to be careful not to let them short. Using double-banana plugs and sockets would be nice rather than using two single-conductor sets.
I found a few more notes about this on the rec.crafts.woodturning newsgroup, below. Some of the advice is questionable but the idea to use the cheap router speed control to reduce the voltage to the battery charger is even simpler than wiring in a dimmer or making a dimmer box. Just plug the charger into the speed control.
If you find you need more/cheaper power, Graeme Priddle has a great idea that I have copied.
Take an old car battery charger - preferalbly without any of the electronic circuitry in it. Use a piece of limp lamp cord to replace the cables - should only be about 3 - 4 feet long for max power. If youi want to use a store-bought burning handle/tip - then pick up a connector at radioshack -- but this might overpower some of those. I made a handle out of 1" pvc, screwed a terminal block (radioshck) to a piece of wood that fits snugly in the pipe. Run 2 - 3" of 6 gauge wire to a second terminal block(gets the heat away from your fingers and the PVC). Design your own tips and attach it to the other side of the second block. Add a light dimmer switch as the power source for the charger, and you are good to go! This is the only method I have found that can keep a hot tip when doing a lot of texturing - -
Good luck - Hought
the battery charger is typically 12V - you'd be better off if you could find an old 6V charger. And, you want to use a newer lamp dimmer - many of the old ones cannot stand the inductive load of the charger's transformer - harbor freight sells a thing they call a "router speed control" for around $10 - that would work fine for this application...... pretty much anything that puts out low voltage high current will work, the key is you need 1 to 3 volts and you need it adjustable.
William Noble
>Thanks, John. That cleared up the banana plug thing. Seems like any 2 conductor connector capable of handling the amperage would cover thin contingency.
Then the nichrome wire is the "weak" short circuit in the circuit between the hot and the neutral? It heats up and allows the burning to happen. The handle is to keep from burning one's fingers.
Don't take this to mean I know what I am talking about. I am just trying to confirming my understanding of what I have read.
On the DIY handpiece, how are then ends of the charger cable at5tached to the ends of the nichrome wire? Some special kind of connectors?
Steven Antonucci
Like this
steve antonucci
>Here is my version of his "woodburner". Like Charlie said, the wood doesn't burn as much as it bursts into spontaneous flames.
As JKJ mentioned, the easiest way to do this without opening a charger is to wire a dimmer to an outlet. Wire to the back of the box, and the dimmer controls the two outlets on the box. The whole assembly plugs into power and the charger plugs into the dimmer assembly.
The two charger leads clip to the terminal posts on the left. Either one goes to either one. The wire that comes off of this is a piece of lampcord, but I have since upgraded to heavy speakerwire because it was more flexible.
The pen is a piece of wood with a hole drilled through it. On the end, there are terminal blocks from Radio Shack. Ask them for them, they come in long strips, and you'll need two at a time. Attach the lampcord/speaker wire to the block. Then strip out two more terminal blocks so that you have a couple of bare ones and take two short pieces of 12-2 stripped copper to make extensions. Connect them to the pen, then connect the two stripped out terminal blocks to the 12-2. This will give you a bit of a heatsink and keep you from melting the terminal blocks every 2 seconds.
Used mine just the other night, and it is an awesome idea for under $10...
Steven
pyro pens *LINK*
>Carol,
>Then the nichrome wire is ... in the circuit between the hot and the neutral?
Yes, except technically (and by convention), on that side of the transformer (the secondary) it is customary to describe the rectified DC output as positive and negative rather than "hot" and "neutral". In most cars (but not all), the negative side of the battery is connected to the frame and called "ground". However, electrical potential is all relative - both sides are "hot"!
Note that considering the current, there has to be a balance between the resistance of the nichrome wire (both length and wire gauge) and the current. If the current is too low for the particular piece of wire or tip you use, it won't get hot enough. If too high, it will glow like a light bulb and quickly burn in two. If you find the higher settings of the dimmer switch are too much for your particular tip, a safety stop could be made by drilling a hole and gluing a pin into the dimmer knob. I did this for the nichrome wire styrofoam cutting system I made for the local high school art class.
BTW, you can buy a coil of nichrome wire from Radio Shack but it's probably too thin for woodburning. You can take apart an old toaster but that wire is probably to flat and flimsy. Wire salvaged from an old hot plate, electric stove, or room heater might be closer to the right size. I'll bet a local appliance/hvac repair guy would be a good source for heating wire in a variety of sizes. (You don't have to use nichrome, but it will last a lot longer than many other materials when heated bright red.)
It's hard to solder nichrome (and soldering would making changing the tip harder) so when connecting to copper I would make crimp connections or screw connections. I might use two stiff solid heavy gauge copper wires embedded in a holder then crimp the piece of nichrome to the ends. However, this also wouldn't make replacing the tip easy.
Better, as Steve mentioned, to use some type of screw connections, the terminal blocks he described, although the terminal blocks I'm familiar with might be a little bulky. Since I tend to build small metal things of brass (easy to work), I'd probably use two brass rods (say 3/16" or less?), file a flat on the the ends, drill and tap for small brass screws to hold the nichrome wire, then embed them into an insulating handle and solder my flexible copper wires to the opposite ends.
Or it seems far easier, just use a commercial pyrography pen with a replaceable tip and just be sure not to overheat with the extra current from this box. The pens I have come with 1/4" phone connectors (like on the end of a midi or microphone or headphone cable, mono instead of stereo, not to be confused with RCA phono connector) that plug into my pyro box so you would have to add a 1/4" phone jack somewhere to the battery charger box or the battery cables.
I remembered a discussion about this a few years ago here on Woodcentral and found this in my notes (this url, also in the link below):
http://www.woodcentral.com/cgi-bin/archives_turning.pl?read=82043&v1=e2vrt43&v2=wood+router+table&v4=lumber+yard&v5=nx3we6g
From that, Ben Aragon describes the parts for home-built pens:
NiChrome wire 18 Gauge
http://www.morelectric.com/nichrome.htm
Pen tubes Phenolic 3/8 ID , 1/2 OD
Monster speaker wire Wire 14 gauge 3ft
Homemade brass connector for Nichrome wire 2
1/8 dia. 1/2" long, 18 gauge & 14 gauge holes
in each end. Silver soldered
And sources:
Ben Aragon -- Tuesday, 13 September 2005, at 11:00 p.m.
I hope this helps answers some questions about pen construction.
Pyrography Pen Parts
Phenolic tube 3/8" ID x 3/32" wall, cut to 5" long pieces
http://www.usplastic.com/catalog/product.asp?catalog%5Fname=usplastic&category%5Fname=79&product%5Fid=25089
Phenolic rod 3/8� cut to 1/4" long pieces with 2 1/8" holes drilled thru.
http://www.usplastic.com/catalog/product.asp?catalog%5Fname=usplastic&category%5Fname=79&product%5Fid=17363
RCA connector 02J8380
http://www.newark.com/NewarkWebCommerce/newark/en_US/endecaSearch/partDetail.jsp;jsessionid=XIBPH2UA23RZCCXFEOFSFFYK2URYSIV1?SKU=02J8380&N=0
NiChrome wire 18 gauge. Cut to 1-1/2" long pieces bent, hammered and filed to desired shape.
14 gauge solid copper wire inside pen 2 pieces 5" long.
Silver solder and Flux for copper to brass to NiChrome connection.
Connectors for NiChrome to Copper wire connection.
1/8" brass rod 1/2" long with, 18 ga. hole at one end and 14 ga. hole at other end
Cable 3 ft length. This Monster wire is very flexible.
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=278-2760
RCA connectors for cable 66F9795
http://www.newark.com/NewarkWebCommerce/newark/en_US/endecaSearch/partDetail.jsp;jsessionid=XIBPH2UA23RZCCXFEOFSFFYK2URYSIV1?SKU=66F9795&N=0
PDF of pen construction, change� use phenolic rod to one end and RCA connector at other end".
Preassemble and slide into tube.
http://www.fishcarver.com/images/burning%20instructions.PDF
Ben
I just found this in my notes, a web site with instructions on making tips and a source of nichrome wire that can be hammered to various shapes:
http://www.fishcarver.com/making_fish_scale_tips.htm
His quick-change tip pen design:
This guy also sells a 3-DVD video course on making and using these (to make fish scales, of course)!
pyro thread from archives
Re: Like this
>Loved the picture, Steve. I did get the part about the dimmer switch. And I am not shy about opening the hood of the charger and messing around inside to effect a tidy package in the end.
Could I get a close up of the business end of your pen? The 12-2 copper is a heat sink between two pairs of terminal blocks? Presumably the nichrome wire is shaped to burn the desired shape? The ends of the nichrome are wired to the second terminal block? Did I get it right?
A picture really is worth a thousand words. Thanks.
And 'heavy' speaker wire? What gauge? Source?
Re: pyro pens
>That's what I love about this place. While I was typing a response to Steve's reply, you were typing one to me. What a wealth of information!
I remember that series of posts. Now it is bookmarked!
Thanks.
>Added some to the Addendum about the Banana Plugs - and a closeup of the working
end of one of Graeme's DIY handpiece - with "custom" shaped nichrome wire.
Note: nichrome wire gets brittle after it's been heated red (or "straw") hot. So probably wouldn't be a good idea to use "used" nichrome wire. New nichrome wire can be bent and shaped - needle nose pliers - or "rosary" pliers work well.
revised addendum - with pic of Graeme's vaporizer
>Thanks, Charlie. That was helpful.
phono, phone, and kill
>Charlie,
Just a small clarification. You mention to "use banana plugs not RCA or phono plugs. the former can handle 10amps, the latter two aren't intended to carry that much." As written, this implies that RCA is different from phono. They are actually the same thing, the white/red/yellow audio/video connections commonly found on the backs of stereos and TVs and game consoles.
I think you have meant to list a different plug, a "phone" or TRS plug. This is often referred to a "1/4in phone plug" since the name "phone" is so often confused with a "phono" plug. These are named "phone" plugs since they were used in telephone switchboards back when a human operator took your call and connected you by plugging in a patch cord. The "phone" plug is called a TRS (Tip/Ring/Sleeve) for stereo or TS (Tip/Sleeve) for mono applications. Miniature and subminiature versions of these plugs are carried around daily by most of the people I know under the age of 30.
Well-built phone plugs can carry more current than the phono plugs but you almost need to disassemble the jacks and look at the construction and the connectors on the plugs to tell.
Based on what I have around the house, 1/4" phone plugs are used in MIDI cables, synthesizer foot controllers, patch-cord synthesizers, audio headphones, microphones, and audio inputs in high-end audio and video studio gear such as audio mixers. (And in some commercial pyrography devices!) These applications use phone plugs since they are low noise and can be quickly, smoothly and reliably connected and disconnected many, many times due to the spring-loaded contact mechanisms. By contrast, RCA phono connections are intended to be connected and left alone - they won't hold up to multiple cycles, are slower and more difficult to connect, and of all the connector types in my video editing suite, the RCA are the first to fail.
And now for a little fun - most dictionaries I checked list the pronunciation of Kiln with the 'n' or either way (Cambridge, Encarta, Websters, Columbia, etc). Those that list both usually list the 'n' version second. I suspect it may be a sphere of experience and perhaps even a regional thing as well: the potters and wood people I know always say "kiln" when referring to the device, but the wood people sometimes but not always say "kill" when referring to the wood drying process, "kill dry". (Usually it's Bubba what says 'kil dried' while Dr Joe uses 'kiln dried' but that's getting off on another tangent. :)
Where did the missing 'n'go? I found this on www.takeourword.com:
Question from 'beth Hayes:
A friend asked me when it became fashionable to drop the 'n' and pronounce kiln as 'kil'. That's what I was taught in Southern New Jersey when I studied pottery. My Webster lists that pronunciation first with 'kiln' second. Her OED doesn't list 'kil' at all. I know we're both right, because we always are, but where would the pronounciation 'kil' have been derived?
Response:
You may be surprised to learn that this "fashion" is actually not as ephemeral as most fashions today. The silent n in kiln dates from the 15th century, in Middle English, The word even appears in the written record from that time in the form kill. However, even though it was not pronounced, the n hung on, so that the spelling was eventually standardized as kiln. Despite the spelling, the silent n pronunciation remained the popular one until recently, We suspect the n is now being pronounced simply because people read the word before hearing it and have no reason to assume that the n is silent. Additionally, the n sound after the l is not all that easy to hear when spoken, anyhow. That may account for the n dropping off in Middle English.
Another similar English word is mill. It was originally miln, but the n became silent and was dropped in this case so that miln was obsolete by the 17th century. It can still be seen in the surname Milner. However, milliner is not related. It comes from Milan + -er, for the goods milliners dealt in were originally from the textile factories of Milan, Italy. It dates from the early 16th century.
Back to kiln: it dates from 725, when it was cyline. It came from Latin culina "kitchen, cooking stove". One obvious relative is culinary, and some less obvious members of this family are cook and kitchen, both deriving from the parent of culina, which was coquina "kitchen", from the Latin verb coquere "to cook". The Romance languages have cognate words for "kitchen", such as Italian cucina and Spanish cocina. And yes, we do see that culina is a rather odd child of coquina. Where did that L come from? No one is quite sure.
What's in a word?!
Steven Antonucci
A picture is worth a 1000 words
steve antonucci
>Here is the requested photo(L to R):
Wood stick with hole drilled down length. Terminal strips are the white things. 12-2 conductor stripped from 2" of wire casing. Terminal strip removed from white casing material. Nichrome wire.
Steven
Re: A picture is worth a 1000 words
Don Orr
>I made a setup like Steve's and it works very well. I'm no electrician but even I wired it together without burning down my house. Turned my own handle and off I went. Nichrome wire from eBay was cheap. I took my unit to 2 club meetings and people were surprised how easy it is to put together. Now I need to use it in a turning ;-))
Steven Antonucci
P.S. Some more answers...
steve antonucci
>In the backdrop, you see the 12Ga Speaker wire I used. It was from Home Depot or similar, and is very flexible, which makes it easier to move the pen.
You'll also notice that I mounted the control box on a long piece of wood. I can clamp it in my bench vise while I sit in a chair to control the amount of current and temperature. Or I can use a hand clamp to attach it to any surface or screw it to the face of a bench...
Finally, the copper terminal blocks also came from HD, and are where the jumper ends of the charger clip to. My desire to not ruin my only battery charge to make a burning pen was met by this design.
Priddle puts the dimmer in the charger and cuts the jumper heads off to mount his pen. Mine requires more setup. I met him over the summer at a club meeting, and he indicated that you need a good 10A or so for it to work. If you can find a good cheap charger at a garage sale, it might be the best of both worlds...
Steve
Re: phono, phone, and kill
>I was hoping to discourage the use plugs other than "banana" plugs. "phone plug" and "phono plug" can easily be confused - one will work, one won't. Trying to remember which is which once in Radio Shack could be a problem and the wrong plug might be bought - and used - at least for a little while. But thanks for noting the distinction.
"English" is a kluged together language with words borrowed from many other languages and often adapted to regional use. Pronounciation must be a nightmare for English As A Second Language folks - the B in "plumber" is not sounded but is in "lumber".
The "gh" in laughter has an "ef" sound, while in daughter it has no sound at all. Toupe and coupe . . . Then there's always the "P' in swimmping". P is always silent in swimmping.
Oh, and if you're wondering about the word "luged", apparently there was a radio manufacturer named Kluge. They made high quality sounding radios that also looked very nice - from outside. Inside it was a cross between a rat's nest and a snake orgy. Seems they weren't much for color coding or even cutting a wire just long enough to connect things. If they needed a 4" long wire, but grabbed a 12" long wire - well there was plenty of room inside the case to stuff the extra inside.
Steve's set up looks klugy to me - but obviously works well for him. The idea of having a metal tool fall and jump the exposed copper connectors would worry the hell out of me - but then I don't do moto cross or skate boarding - call me cautious in that respect. Frugality often requires compromises.
When you consider what a commercially available "pyrography" rigs costs, and the price tag of many of our turning tools, $50 or $60 for a dedicated Wood Vaporizor - with the variable power dial built in and plug in "vaporizor tool" - seems pretty inexpensive. As is often the case - you can pay up front in dollars, or pay later in time.
However you get there ain't that important - unless you get hurt on the way there.
Re: P.S. Some more answers...
>Thanks for the picture and the addition information, Steve. It is all dutifully filed for future application. I have an old working battery charger. Maybe I'll just get a new one for the car...
Re: You didn't mention about ......
Jamie Donaldson
>....driving on parkways and parking on driveways?
phono, phone, banana ID
>for a little while.
Then perhaps a picture would be encouraging. The phone plugs seem like a good possible choice to me since my pyro pens already use them and they handle both conductors in one housing. If using banana, go with the twin plugs and jacks.
phono, phone, banana ID - updated
>After discussion with Charlie, I added a picture of a miniature phone plug. The relative sizes are approximately correct.
Remember that all of these carry two conductors except for the banana plug. If using that instead of the 1/4" phone plug, you must use a pair. For that reason and others, the 1/4" phone plug would be my first choice.
The two at the bottom may work but have several functional and safety disadvantages. There are many other types of connectors that would work. Have fun!
