Somewhat OT: shavings and compost
ILYA ZAVORIN
>I am trying to make compost in the back of my yard. During the summer I have the problem that I have lots of grass clippings and little "leafy" stuff. A pile of clippings turns quickly into a pile of stink, as it should. So the question is: can I balance my compost with shavings that I generate with my chain saw and lathe? I work with different types of wood, mostly hardwoods, sometimes coniferous, in both cases mostly green. Are they all good for composting, or are some better than others? Thanks.
Re: Somewhat OT: shavings and compost
bill Crommett
>Just don't put any Black Walnut shavings in the mulch pile. They will prevent anything else from growing.
Ken Oakley-Sunny St. Cloud, Fla
>Shredded newpaers works well as does coffee grinds, egg shells, scraps from vegetables you prepare to cook and then good old cow or horse manure just makes it that much better.
arkie
>Yes, all those things compost, but the grass clippings give you lots of nitrogen and moisture, perfect to make bacteria and fuungus grow, but nothing much for them to eat. You need carbon, and probably in a reasonably dry form. Wood shavings will serve that function, as would dry leaves or shredded newspaper. Manure and coffee grounds add more nitrogen and won't help.
As for black walnut. Juglans or juglone or whatever name you care to give that growth inhibitor is released primarily by the root. I've composted walnut shavings and noted no adverse effect. I wouldn't use walnut for animal bedding, particularly for horses.
Sean Troy
>how long does an average compost pile take to be usable in a garden?
>From my references, the bacteria that decompose wood chips and sawdust require more nitrogen than other greens so they should be mixed with other materials. I read that decomposing wood will increase the acidity which is especially great for blueberries and evergreens.
I make big compost piles primarily with horse/goat manure and old hay (and whatever else I can scrounge) mixing with about 1/2 soil, turning occasionally with a tractor. I do mix sawdust from my sawmill but not in great quantities and the compost seems to work fine. The biggest problem is keeping the piles moist enough in the drought these past two years. I generally compost one year and use it the next. I spread some on fields with a manure spreader and till the rest into the garden.
Barbara Gill, Remlik VA
>Arkie, I have found the same to be true of walnut shavings.
Allen Neighbors
>When I composted, I'd turn it once a week. Start it in spring, use it in fall.
If you don't turn the pile often, and keep it moist enough to work, use it the following year. You should be alright with this.
When you dig down, and it's become loose, black, non-stinky loam, it's ready to use.
Keith Tompkins
keith tompkins
>Hi John, you are correct, when wood shavings are used in compost,it causes nitrogen in the mix to become unavailable, tied up by the bacteria in the process. When fully decomposed, the dying bacteria release the nitrogen back into the mix, making it safe to use. Don't till shavings directly into garden soil.
bill Crommett
>I once was under the impression that it was only the roots of the Black Walnut trees that produced the Juglones, but I found that dumping mixed shaving in the orchard cause several of my fruit trees to die. I realize that there are several causes of fruit tree demise, but I no longer take chances with Black Walnut shavings. Perhaps properly composted Walnut shavings would have the evil spirits evaporated and safe to use.
Keith Tompkins
keith tompkins
>Speaking of compost, I'm ready to plant next year's garlic crop,I purchased "seed" for ten or so varieties at the Garlic Festival in Saugerties, NY last weekend. I'll have over 200 plants...that should do it! Compost is the best fertilizer!
>Don't plat too close - it will spread. My elderly neighbor gave me some to plant this year that she has harvested for the last 40 years!
jim miles
Jim Miles
>My azeleas are sick -- I think from -shavings from walnut, cedar or exotics
