scrapers
scrapers
scrapers
bob henry
>Going to take a bowl turning class and students have to bring their own tools. I have everything but the round and sqare scrapers. They list a to have a round and sqare scraper between 1/2" - 1". What would the best size to get and not turning any bowls over 10". Thanks for any help.
Bob
Re: scrapers
Re: I can't imagine why anyone ......
Jamie Donaldson
>...would need a square scraper for turning bowls??
Re: scrapers
Re: scrapers
Ralph
>I like big heavy, thick scrapers...
But I don't understand square, well, on boxes or other forms with square, flat bottoms...
Re: scrapers
Re: I can't imagine why anyone ...... *LINK*
>Maybe the instructor uses a square scraper to flatten the inside bottom of the bowl or detail under that foot. If the former, it better be rounded a bit on the corners.
Bob, I generally like 3/4" to 1" flat scrapers, and mostly use those rounded on the left side, usually the thicker the better for stability. Flat scrapers which are 90 deg across have slightly rounded corners, flat scrapers intended to be used on the outside are ground at an angle for better control.
However, most of the time I reach for a sorby tool with a teardrop scraper blade that can be rotated to various curvatures or a flat spot for the outsides. I have these in two sizes and one with a curved neck to reach inside of closed forms. This is also great for a bowl with a lip inside.
sorby multitool
Re: scrapers
Re: scrapers
bill Crommett
>----for sheer scraper on nasty wood !
Re: scrapers
Re: scrapers
robo hippy
>For an all round scraper, a 1 inch round nose will do fine. I prefer the ones that are quarter round, or swept back towards the left. This works best for the inside of the bowl, and if you start with a face plate on the top of the bowl to turn the bottom, then reverse and remount with a tenon or a recess, it works with the outside as well. The only reason I can think of to have a square one would be to form the sides of a tenon, which have to be square, or match the angle of your chuck jaws.
robo hippy
Re: scrapers
Re: scrapers
eliot d
>I often use a square scraper for a final, very light pass over the outside. If the corner of the scraper ( the one you might designate as the "northwest" corner) is rounded, then such scrapers can be very useful for turning the inside of a smallish box.
Re: scrapers
Re: scrapers
>Me too Eliot. I like my small flat scraper for fine cuts on the outside. If it's a larger vessel I use the John Jordan scraper in shear scrape mode.
Like Jamie suggests I rarely use a scraper on the inside anymore. I do use a smaller round nose on the inside of some boxes but I'm using the Hunter tool more and more for these. It leaves a much better finish quality than a scraper even in shear scrape mode.
Re: scrapers
Re: scrapers
JERRY COX
>my 3/4" square scraper leaves a clean finish, when shear scraping outsides of bowls & vessels...very little sanding is needed...
the scraper can easily be reground to another shape, if needed...
Re: scrapers
Fog Tanner
>I use one quite a bit on the inside and outside on of 6"-23" bowls. It actually started out square, but has a slight radius to it much like my skew. The other one I use has the same profile except it has a 45 degree bevel, which is great for shear scraping in the outside of the bowl. I use them on the inside of the bowl for smoothing out the tool marks and refining the shape. The profiles on each can be found in Raffan's books on bowl turning, he is the one that gave me the radius and taught me how to use it. It is unbelieveable the amount of wood he can remove when refining a surface. He also doesn't waste a lot of time trying to get a perfect gouge cut in the bottom (inside), going to the scraper instead.
