sanding sealer
richie c
>Ya know, I just bought this sanding sealer, and Im not sure how to use it! Do you put it on a turning before you start to sand it or after the sanding is done?
sanding sealer
richie c
Re: sanding sealer
>What I use is lacquer-based. The instructions said to apply it and let it dry before sanding so that's what I do. It may take hours to dry. I also use it to toughen up wood that tears or is a little soft.
Re: sanding sealer
davidwalser
>Richie,
It might help if you'd let us know which sanding sealer you bought in case anyone has helpful hints regarding that particular brand or type.
Re: sanding sealer
Mike Jones, Redding, CA
>My best advise is to refer to "Russ's Corner"...found by highlighting "Articles" in the left column on the page.
Re: sanding sealer
richie
>yes, its mylanders cellulose sanding sealer.
Re: sanding sealer
Ric Taylor
>richie,
Mylands is what I use. I put on a coat and sand it off between every grit of sanding from 180 or 220 through 400. This results in a glass-smooth finish. Sometimes I don't bother to put any other finish on top of it, because buffing with the Beale system gives a nice semi-gloss surface.
Ric Taylor
Re: sanding sealer
richie
>thank you all NM.
