lathe centering problem
bob henry
>When I turn a square to a round and later turn the spindle around the spindle is out of round and have to round it again. I can't turn a spindle around without it being true. I checked the tailstock point against the headstock point and they match perfectly. Is this a common problem or do I have some sort of problem? Thanks for any help .
Bob
Re: lathe centering problem
>2 things come to mind. If the center points are not the same size it can easily slip off center. The same would be true if they are not penetrating far enough, think 1/8" hole with a 1/16" pin, there would be some slop letting it slip.
I'm interested in why you need to flip the spindle. I have done it myself on rare occasions.
On think I do on my drive centers is to notch one tooth. This leaves an impression you can see so you can get the same tooth in the same spot. Then if I ever have to remove the spindle I can put it back exactly the same way it came off and I get perfect alignment.
Richard Allen
Richard Allen
>The Oneway safety drive and the Oneway live center have the same profile. In this way you can flip a spindle end for end and maintain alignment.
bob henry
>I'm using the Oneway drives.
Bob
>When you checked the centering on the tailstock was the quill extended the same amount that it is when your turning. It could be off when the quill is extended and on when it's all the way in if the tailstock is twisted.
bob henry
>What I was making was a peppermill. The reason for me turning the piece is because it is easier for me shape the top of the mill on the tailstock end rather than near the headstock. In turning it around I put the part with the 1 5/8" hole at the tailstock using the jaws of the chuck inside the hole. Bear with me newbie at this.
Bob
>It's not uncommon for a piece to be offcenter slightly when gripped with chuck jaws. Some jaws aren't perfect and sometimes the jaws bite differently into one area of the wood. It's best to use jaws that just barely fit when closed to avoid sharp corners of the jaws. Otherwise, I don't know what to do about it except make sure the tailstock end is aligned when chucking the piece (a cone center in the tailstock may help if the hole is drilled), or add a little tape to the jaws to recenter by trial and error. I like the aluminum HVAC tape.
Also, sometimes a hole drilled on the lathe, especially a long hole, can wander a bit out of center which would cause problems when rechucking internally. Can you protect the wood and chuck externally? Otherwise, a good quality forstner bit may help. I like to use a carbide-toothed bit and blow compressed air into the back while drilling to keep the chips clear and keep the bit cool.
Grant Wilkinson
>Bob
You said in your last post that you put the end with the large hole in it at the tailstock end and that you are holding that end with the jaws of the chuck expanded into it. That would mean that your chuck is on the tailstock. Is that what you are doing?
>I agree, the hole can easily be offcenter. I don't make many peppermills but when I need the hole to run true I drill the hole first and do the turning last.
bob henry
>No I put it at the headstock end.
Keith Tompkins
keith tompkins
>I would guess you are holding the piece in a chuck, drilling the hole with the drillbit held in the tailstock. Then, you reverse the turning, using the chuck in the headstock, and using the tailstock center to hold the piece to turn. If you are drilling the hole while the blank is being held by a spur drive only, there is a lot more room for error. If you are drilling the hole in a drillpress, even worse.
One solution: Mount a piece of scrap in the chuck, from this, turn a cone. The cone will self-center the drilled end in the headstock. Bring up the tailstock, using a previous center mark for accuracy. The blank should turn true.
turning sequence *LINK*
>Bob,
I forgot to mention: check your chuck jaws. If your chuck is like the supernova I use, double check that the jaws have are fastened with the numbers matching the numbers on the slides.
Also, I did buy a set of jaws once that were bad. Jaws for my chuck are made by machining a circular shape then sawing it into four pieces to make the four jaws. The pieces should be a matched set. I bought one set of jaws that obviously had some jaws mixed with those of another set. Those jaws never would run true so I exchanged them.
You can close the jaws and turn the lathe slowly or by hand and check to see if there is any irregularity or runout.
Also, I agree with what John Lucas said - I've made several peppermills with the crush grind mechanisms and I always did the same thing - shaped the outside after drilling the hole. Briefly: roughly round the outside; chuck one end (cut a tenon if necessary) and drill the larger holes and the long central hole; reverse and chuck on the outside and drill the top alignment hole then finish the central hole from that end if necessary; turn jam chucks for each end; with one jam chuck held in the four-jawed chuck and the other supported by the tailstock, shape the outside; turn and fit the top.
In the link are instructions with some illustrations.
http://www.crushgrind.com.au/instructions.php
