Lathe Mobility Question
Steven Antonucci
steve antonucci
>One of the clubs I belong to has a very nice Oneway 1224 which needs to be carted in and out of our meeting place. As such, we have it mounted on casters. While it makes the lathe nice and mobile, it als makes it less steady than I've seen other Oneways.
I thought I would make a removable base for once we got it into the meeting room, and that we could just lift it and unscrew it at will. And then I attempted to lift the tailstock end. And it didn't budge. Not even a thought of moving.
So, I need a design for a Oneway or other large, heavy lathe that will allow it to be set on the floor once in place. I think it should be simple to raise and lower, and shouldn't require the user to lift anything as heavy as a Oneway, since a lot of the club members probably aren't going to want to hurt themselves.
Does anyone have an elegant solution to a simple problem?
Steve
Re: Lathe Mobility Question
Ken
>They make casters for moving heavy machinery that you mount on the legs,then when you get it where you want it,you just release them and set it down on the floor.It can be done with your foot.I have used them in the past and they work good.Sorry but I don't know where you can find them.Try a google search on casters an you may locate them.Hope this helps.
Ken
Steven Antonucci
I found my answer- now I just need to find the...
steve antonucci
>right product at the right price! I need leveling casters capable of supporting about 700# of lathe.
I've found a few suppliers, and they all seem to have the same pictures, but prices are all over the place. Any ideas what the "right price" for the leveling caster should be?
Steven
nailed_nailer
>Steve,
I have used something like these in the past to move heavy electronic cabinets. They work great.
Something like these would work for you.
http://www.randmh.com/wesco-manual-furniture-movers-1320-lb-capacity-272951/lift-trucks/
At $500 + shipping it may be overkill but it will work.
Good Luck,
---Nailer---
Re: Lathe Mobility Question *LINK*
John Uteck - Charlotte, NC
>The NC Woodturners use the removable Oneway wheel set -- see below link. You might be able to fabricate something similar for your application.
Oneway Wheel Set
>or something like the wheel set for the 1640, at the following link.
Wheel set for the 1640
Jack Brown, western PA------WebKitFormBoundaryoqt2
>Try www.castercity.com they have all kinds of casters. I have bought a lot from them, the owner even called me when they didn't have what I ordered.
Jack
Great lakes Caster *LINK*
Jake (SoMN)
>Steve,
Try great lakes caster, they are the most affordable place I have found. Zambus makes a similar product but at 3 to 4 times the price.
Great lakes Caster
>Our club meets at the local Woodcraft store which has a lathe that gets moved around for demos and classes. They built a wooden platform with slots for an inexpensive hydraulic hand pallet truck. This is easy to move around and when let down, sits solidly. It does raise the lathe slightly, but a small wooden platform for the presenter to stand on will make the demo easier to see.
If you can weld, I can envision a steel frame that can still be used with the hand truck but would only raise the lathe 1/4"
Oneway 1224 Weighs 300 Lb.......
Wally Dickerman in Arizona
Fog Tanner
>I bought a set of stub casters from Granger's to move my Vic 300 around. It weighs 1000lb and each caster is rated for 350lbs. They work OK as no one caster has 1000lb load on it and I am not putting 700lbs on one end at any time. I use a sissor jack from an Aerostar to raise the lathe for mounting the casters. There are four holes in the base that can be used for that.
Fog
Re: I found my answer- now I just need to find the
Grant Wilkinson
>Vega sells a machinery mover that has the machine on the floor when you are using it. I have one under my 2600 and it is great.
Re: I found my answer- now I just need to find the *LINK*
>I've been thinking about these. I figure all four could support over 600 lbs in motion.
Casters
Bob Macgregor
>Its too bad air pallets cost so much. A full-size lathe, like the PM, say, has an air pallet footprint of less than one psi and would be really easy to glide over a smooth shop floor (though I'll bet it would really stir up any dust lying around the shop!).
BOB
Steven Antonucci
Just the lathe or with the stand too?
steve antonucci
>I tried to lift it to get a sense of the weight and it didn't budge. Not an inch. My Nova, with the cast iron legs and ballast box is probably 500# and I can move it pretty easily...
Steve
Steven Antonucci
Price is right! Thanks.
steve antonucci
Re: Just the lathe or with the stand too?
>The 300 lb. weight comes from Oneway's catalog. The illustration shows the lathe on the stand.
Wally
wilbur
>Something to think about -- when it comes to moving something as long as a lathe, there's probably more than total weight that goes into your ability to move it. Unless you're huge, and I mean Incredible Hulk-type huge, when you're trying to move a full size lathe you're not picking up the whole thing at once, but moving one end at a time.
In which case, the lever action of picking up one end of the lathe while the other end is resting on the floor comes into play, and how the weight is distributed will also determine how easily the lathe is moved.
I'm no physicist or mechanical engineer, but from what I remember about levers from high school physics, I bet that trying to pick up the end of a 500 lb. lathe and stand when most of the weight is in a sandbox near the floor is going to be easier than picking up the end of a lathe where most of the weight is at the level of the bed and headstock.
Steven Antonucci
I'm not a mechanical engineer either ...
steve antonucci
>(but I did study a lot of ME classes at a Top 5 engineering school :-)
The distance to the floor is probably somewhat contributory to the complete lack of and notion of lifting the tailstock end, but it really blew me away. I don't know if we had a secret lead filled balast box, but it didn't move at all It was as if it was cemented to the floor, even though I know it is on wheels.
When I say that I can physically lift my Nova, I mean <1" on the tailstock side. I'm not the Hulk, but I can easily lift a couple of hundred pounds. Maybe the weight Wally posted was in kg?
Steve
Re: I'm not a mechanical engineer either ...
Tommy Holmes
>All the written information I have found say 300 pounds. I have one and I agree with Steve, it feels more like 600.
Ed Pang
>I just installed a wheel kit for my Oneway 1224. You can lower the wheels to raise the base and then move it to a new location. Once in place you can raise the wheels and then it will sit on the base. By using a lever that is provided in the wheel kit you can raise/lower the wheels. I got the kit directly from Oneway. I did have to drill holes in the side of the base to install the wheels.
