Veritas - Innovation in Tools
starting NE bowls between centers
Leslie
>Hi all,
I'm hoping I can get some input. I start my natural edge bowls between centers, I shape the outside of the bowl and form the tenon. (I use a barracuda II chuck to finsh the bowls) Often (read always) when I want to hog off some material I invariably slow the wood down and it ends up spinning on the four prong drive in the head stock. This happens when i don't get a catch. I tighten the tailstock end adn the dang thing moves along the ways. What can I do to prevent this from happening? On an unrelated note I would like to make a wooden drinking cup and wonder what others have used inside the cup for waterproofing? Any input is appreciated.
Thank you,
Leslie
Re: starting NE bowls between centers
arkie
>You can drill a small hole for the center point of you spur drive. You can also clear off the bark and cambrium down to bare wood. Drive the spurs into that wood with a mallet before installing the spur drive into the lathe. Also, orient the spurs so that they form an "X", not a "plus" so that all 4 spurs are evenly engaged.
Carole Valentine
>Hi Leslie,
First of all, drill a hole the size of your spur center through the bark and into solid wood. Drive your center in, then pull it out and drizzle thin CA glue all around the impressions and the solid wood area. Let it dry then reinsert your spur drive. The glue will harden the wood so you don't get spin-out - at least not unless you get a huge catch.
Regarding your tailstock moving along the ways, it sounds like you need some adjustment to the locking plate. There should be a screw under it that will let you tighten it a bit. A little goes a long way.
Peter Teubel
>I use 2-prong spurs exclusively. I drill a 1.5" hole just thru the bark with a forstner bit and pound the spur in-line with the grain at least 3/4" deep. It NEVER slips....ever.
Carole Valentine
>3/4" deep??? Wow...that's a big spur drive for big wood! I guess it doesn't slip! LOL I also use 2 prong drives exclusively. Good catch on aligning with the grain - that is a must (unless it's burl.)
Roger
>I put a screw center in my One way chuck, drill the appropriate hole in the blank (11/32") for my screw center. Screw the blank on the screw center, turn a tennon on the other end, unscrew the blank, take screw center out of chuck, mount blank onto chuck, and you're ready to turn. For me it's quicker than putting spur drives in and out and the screw doesn't slip, as it goes through the bark and into solid wood.
>All of the above is excellent advice. I found that using a larger center works for me. The one on the left is a drive center that used to be made by Bestwoodtools but they now only make the large drives that fit in the chuck which is quicker to use. They make them in 2 and 4 prong drives. See the link below.
I made the one on the right which can be used right throught the bark. The teeth are a little long for some applications so I'm going to shorten them.
don lewonczyk
>John, did you drill the holes in the one you made and CA the shanks in? It looks like it'll get the job done. Good to hear you have some new additions to your shop, you could never have enough tools even if you used it only once a year. I got most of my tools by convincing MBH that I could do the job as well as anyone but I needed the tools to do it with, it worked every time! Slow down man and smell the roses life is to short, I haven't had a break in 23 years with this cattle farm, 7 days a week 52 weeks a year. If I could go back and start over I would do things a little different. Our oldest son 47 passed away the 23rd of Aug but we think he actually died on the 22nd our 49 wedding anniversary, we found him in bed on the 23rd and he was coming by on the 22nd but didn't show up. Stroke or heart attack, not sure which, you just don't know from minute to minute what will happen and its proablly a good thing that we don't know. Take care John. DonL
If you're using the tailstock...
Allen Neighbors
>to tighten the blank onto the spur drive, you're exerting too much pressure on the live center and spindle bearings.
The others have suggested driving the spur into a drilled depression. I second their comments.
Another suggestion: I modified my Spur drive. Using a dremel, I sharpened the spurs, and ground the shoulders flat, so they would hold better in the wood.
>>...it ends up spinning on the four prong drive in the head stock.
I've read that a drive with two spurs rather than four is less likely to spin in this situation.
Wow, Don, You've been...
Allen Neighbors
>through a rough time. I can't imagine the hurt you've been through. My condolences to you and your family.
Carole Valentine
>I'm so sorry for your loss Don. My heart goes out to you and your family.
>Don I'm so sorry for your loss. I'm listening to you. I'm going to try to slow down. Of course that's easier to say than do for me.
I Think I epoxied the pins in the nut. If I make another one I will make the pins shorter. I built this to penetrate soft bark so I could rough out the bowls quicker. I find that your still better off taking the bark off in the area near the center. The good part about this drive center is that it's very easy to shift the center for better bowl alignment although I wish it had a spring loaded pin because you can easily shift the bowl too far.
>I once saw a somewhat similar idea in an old FFW magazine but on a larger scale. This used a standard faceplate and several bolts sharpened on the ends, held in place with multiple nuts. I think the idea was the length of each point could be adjusted as needed to accommodate an irregular piece like a burl, but it would probably work just as well to use shorter bolts inserted all the way without room for adjustment if the faceplate diameter was not too great.
Leslie
>Tahnk you all forthe suggestions, I will keep trying. I knew I would get ansers here
Bigger things
Dave Peebles Lyons, Ohio!
>Hello Don,
I just wanted to send you and your family my best wishes. You will all be in my thought tonight.
David
>John Something similar to that is in my plans. I thought having points that would be adjustable might help align platters that are warped. I occasionally turn platters out of older green cut pieces and they are always cupped and sometimes bowed as well. To get the thickest pieces you have to carefully align them. Once aligned I turn the bottom with a recess for the chuck. Having a larger drive center with adjustable point heights would really make this easier and more accurate.
Platters
>John,
If you turn platters, do you need any slabs? The reason I ask is I sliced up a fat e.r.cedar log for Frank Penta who said he likes cedar for platters. This log had a lot of variegated white/red figure. I'm going to take a few slabs when I visit Frank next week but I have extra.
These are 14-22" wide, 2" thick, about 50" long. They've been stickered for just a month but erc usually dries for me without warping.
