Laser tachometers
wilbur
>I am getting an old Conover lathe tuned up. Currently it has a pulley speed change setup, with a four step pulley on the headstock, a four step pulley on a short jack shaft, and a two step pulley that couples the jack shaft to the motor, which gives a total of eight possible speeds. Problem is, I don't know what those speeds are.
Has anyone used a laser tachometer for determining RPMs? That's the easiest way I could think of for measuring the actual RPMs.
