Is this who I think it is? *LINK*
Peter Teubel
Bandmill
Peter Teubel
Bandmill
I hope not...
Steven Kubien
>Good heavens I hope not. Granted the picture is not really clear but I do not see any evidence of guards or personal safety equipment of any kind.
Kinda scary to me
Steve Kubien
sure looks like someone we know to me. :)
>I used to have plans for a bandmill like that. I think I finally tossed them out in the last move.
Re: I hope not...
Barbara Gill, Remlik VA
>Steve, the only personal safety equipment that is necessary is for hearing and breathing protection. As long as they stand behind the band the lack of guards around the band shouldn't make a difference.
When a band breaks, it doesn't go flying. It pretty much stays right there in the kerf.
Re: I hope not...
>I agree with Barbara. I consider my bandsaw mill safer than my little Delta bandsaw because there is no way to get into the way of the blade unless perhaps you get really drunk or try to film something for America's Stupidest Video. A broken blade in the wood will instantly stop. It is very unlikely to break a blade when running free but still, you never stand in line. You are more likely to be hurt handling logs and boards than sawing them.
The biggest danger of having no guards may be from small flying pieces of bark or splinters but even that is minimal. It's a whole lot safer than a chainsaw. But like a chain saw, don't saw without personal protective equipment. I usually use my Stihl helmet with hearing and eye protection.
Not a sawmill with a circular blade is a different story. Think "kickback" enough to throw a 4x4 at you.
BTW, the last couple of weeks I've been sawing a bunch of logs for my new barn. I saw them into "cants", the biggest rectangle I can get from the log. Once squared off, it's a simple matter to load a cant and slice off boards the size needed.
Re: Is this who I think it is? - Ok, I'll bite...
Ray Carson - Lawrenceville, NJ
>Who is it?
Ray
BG
Allen Neighbors
Unguarded Saw Blade...
Wally Dickerman in Arizona
>When I was a teenager I worked for a summer in a shingle mill. The circular cut-off saw was 7 ft. in dia. and had no guard. Just the wind created by that thing was scary. The 54 in. cedar shingle bolts were put on a sliding table and the sawyer ran the bolt into the saw by hand. trimmed the ends and cut three 16 in. blocks to be cut into shingles.
Wally
Re: Unguarded Saw Blade...
>With some of the money I made working at the mill I bought my first ever woodlathe. A Sears Dunlop, about the size of today's mini lathes.
Wally
Think 20ft razor blade.
>I had to photograph a factory where they make the 6 and 8" thick foam mattresses. They have what lookes like a horizontal bandsaw but it runs a 20ft razor blade. It doesn't make any noise, just a whir and wind. You talk about scary. They slice off 6ft wide by 8" deep pieces
John
>"BTW, the last couple of weeks I've been sawing a bunch of logs for my new barn. I saw them into "cants", the biggest rectangle I can get from the log. Once squared off, it's a simple matter to load a cant and slice off boards the size needed."
The problem with that approach is that the outside of the cant dries more than the inside; it takes years for the moisture to equalize throughout the whole cant. When you resaw, the cant will move toward the driest side even if you flip it 180 degrees for each pass (lots of work). This will result in boards that are thicker in the middle and thin on the ends. DAMHIKT
Or His Twin ;-)
I stand corrected
Steven Kubien
>Barb and John, I'll take your word for it. You two have way more experience with this sort of equipment than I do.
Thanks for setting me straight.
Steve Kubien
-still looks dang scary though!
Re: I hope not...
Dick Hines
>My grand father worked as a mill wright for 40 years. You should have seen the lack of safty equptmment. This was in the 30's-40's and 50's.
He got out with all his fingers and toes. They did not have band mills then. The mill used a saw blade that must have been 5' in D. They also had a cut off saw that was hinged to a rafter of the mill shead and was run with a belt off the main motor, flat head V8 truck motor, the belt ran to a pulley that ran the saw blade. NO GUARD!
Re: Or His Twin ;-) - now THAT"S scary!
Carol - now back in Dubuque, IA
Re: Or His Twin ;-)
That's OK for this project - I'll cut these into boards within a few weeks and use them green without even stickering. Much will go to B&B siding, some to line horse stalls. I've already got quite a bit of air dried lumber to use where needed. But I almost hate to use the 8/4 cherry and walnut for rafters - better used for flooring, eh? :)
Re: Or His Twin ;-)
>Yep, cherry and walnut make good flooring.
Peter Hyde
>Here's another shingle saw. I guess things don't change much.
Re: do maple rockers slide on a walnut floor?
Mike Hamilton
Bill Grumbine - Kutztown PA
>Well it isn't me. That guy is lucky to be so distinguished looking though!
Re: Does this mean that Bill.......
Jamie Donaldson
>....really does have a twin somewhere??? (:-O)
