Diamond hones
Diamond hones
Diamond hones
>Any recommendations for a source for these little diamond hones? I use the superfine (blue) constantly to touch up tool edges. (Touch one of these to a Doug Thompson gouge and the wood almost cuts itself.)
Woodcraft doesn't sell this type anymore and I don't like their replacement.
I found these on the web from around $5 to $6 each, a bit cheaper in a set. I'd like to buy about 10 each of the blue and the red. Anyone use these and have a preferred supplier?
Re: Diamond hones
Re: Diamond hones
Ray Binnicker
>John,
I see them listed at Rockler.com.
Ray Binnicker
Re: Diamond hones
Re: Diamond hones
Brian Hahn in SW Wisconsin
>I love those hones. I stocked up when Woodcraft discontinued them. I just happened to stop at Woodcraft to get some of those hones on the day after they took them off the shelf. They still had them sitting in a basket and I really stocked up.
To answer your question, McMaster-Carr (www.mcmaster.com) carries them.
Re: Diamond hones
Re: Diamond hones
Don in Ellensburg,WA,
>page 2631 in their online catalog
5.88 each for both blue and red unitgs
Re: Diamond hones
Re: Diamond hones *LINK*
LARRY BISBEE
>Rockler Woodworking and Hardware have the 3 Piece Diamond Hone Sharpening Set in stock under Item #24663 for $15.99 plus shipping.
Re: Diamond hones
Re: Diamond hones
>John Those are the ones I prefer also. You can get them at Smoky Mountain Knifeworks. I buy them locally at a knife dealer here in town but whenever I'm out your way I have to hit the smokey mountain knifeworks.
Re: Diamond hones
Re: Diamond hones
>Thanks, everyone. I see Amazon has the sets as cheap as anyone but Smoky Mtn Knife is close.
The cheapest I've found today on the individual hones was $4.19 but it's hard to know who to trust. I started looking harder and found the EZE-Lap company itself seems to have a good price on individual paddles ($4.95 ea). I was hoping to buy just the fine and extrafine in quantities instead of buying a bunch of sets since I don't use the coarser hones. Maybe I'll call and see if they have discount quantity pricing.
Re: Diamond hones
Not all Diamond hones are equal
Ron in Drums PA
>You really get what you pay for.
The cheap hones that others have shown here break down quickly and even do a lousy job when new. Just not worth it. I put them in the junk category.
Alan Lacer sells a fantastic hone that really works. Go to his home page, click on tools then scroll down to the hones.
They are not cheap, but one will last you a life time.
The best one for turners are the 600 grit hones.
Re: Diamond hones
Re: Diamond hones
Raymond Overman in SC
>John,
I got mine from Klingspor locally in Charlotte. I think they distribute for Rockler now so that's where they may be coming from.
Re: Diamond hones
Re: Diamond hones
Don Orr
>Enco has them also.
Re: Diamond hones
make your own-easy and cheap
Bill Tindall, E.TN
>For 300 years diamonds have been "cut" by embedding diamond powder in cast iron and grinding away. One can do the same to make a hone. Obtain a piece of gray cast iron the size and shape of a hone. I cut these from scrap cast iron. Embed with diamond paste available from any machine shop supply or lapidary shop ($15)and go to town. I use WD 40 lubricant, but olive oil is traditional. Only a tiny amount of paste is necessary to charge the stone, perhaps a mm long "worm" for a typical hone size.
The same approach is useful for chisels and plane irons, except a larger piece of cast iron is used.
Re: Diamond hones
Follow up
>As a follow up, I ordered a quantity direct from EZE-Lap. They offer a 25% discount if you qualify.
They said that as of an agreement about 2 weeks ago, WoodCraft will carry EZE-Lap products again.
