cured the warp
cured the warp
cured the warp
Darryl
>This is certainly not a wow thing but thought I'd share it. I hollowed a cylindrical bowl ala Bin Pho to do some piercing. As the bowl dried it of course warped badly. It was almost to the point of burn pile. I had used alcohol to dry it. The wood was relatively green birch. Having nothing to lose I re-immersed it in alcohol for a few days and then put a hose clamp around the top edge as it dried. I had to re tighten the clamp periodically as the bowl dried. Result has been an almost cylindrical bowl for now.
Re: cured the warp
Re: cured the warp
Allen Neighbors
>That was some good thinking, Daryl. I never thought about re-soaking a piece!
I'm going to try some bar clamps across the end grain of some bowls to hold down the warping while in the drying stage. Wish I could get some clamps that are 12 to 24 inch size!
Re: cured the warp
Re: cured the warp
>At our last club meeting a gentleman showed how to wildly distort a turned piece by heating in a microwave until hot then applying clamps. If needed, he soaked first in water. The same thing should work for undistorting a piece. The pieces used as examples were turned thin. Face work such as bowls requires special care at the end grain where there is little strength. He said this bending technique was not useful with certain types of wood, such as oak.
Seems like steaming would work as well as microwaving, just as in bending flat work.
Re: cured the warp
Re: cured the warp
Dick Coers
>Allen, check McMaster-Carr, part number 5540k22. It is a make-your-own clamp and comes up to 100 feet long. It's 304 stainless so will work great with wet wood.
Re: cured the warp
Thanks, Dick,
Allen Neighbors
