>Need advice on how to preserve bowl blanks from green wood so that they can be turned later.
There are situations in which I don't have time to rough turn all of the green wood I collect and/or am not sure what I might want to turn in the future.
I have tried cutting logs into blanks with the chainsaw and either painting ends or entire surface with end grain sealer. Invariably, they all crack right up the center (pith is not included in blank). I have some smaller blanks that I have collected from club raffles and such that have not checked (they are not even sealed).
The only differences I can see are: 1) the smaller blanks were cut on a bandsaw and 2) the smaller blanks are not as thick (2-3" thick as opposed to 4-6" thick).
Is there something I am missing? Do you have a process that works?
>Virginia, where I live, is humid and maybe that accounts for my lack of problems with checking.
I line up the pith on each side of a log, using a spirit level in an upright position to establish cutting angle, and then I cut slabs and bandsaw them into circles and seal them with anchorseal. I mostly work with cherry, maple and elm. They are stored in my wood shop which is not heated or insulated, and I lose very few to checking. Size varies from 8" to 20".
>Large chunks of wood will crack eventually; some faster than others depending upon the conditions. The best way to preserve them is rough them out. If you don't do that, some will be lost. The smaller ones are not subjected to as much stress as the larger ones.
If you rough out a bowl and leave it much thicker than it needs to be then that blank will be more likely to crack. I too live in Virginia. The high humidity here along with sealer slows down the drying rate but it does not prevent the blanks from eventually cracking.
I too have found that removing the excess wood with a bandsaw or chainsaw will in some cases help but eventually the large pieces will crack.
Cut the pith out and leave extra on the ends. Seal the end grain with 2 coats of Anchorseal and any other raw wood with one. Get the wood out of the weather. Remember, where a branch is cut off you have end grain. This will slow down the drying (cracking) but not prevent it eventually.
>As mentioned, remove the pith. I know we all want to make the blank s as big as possible, but MORE of the pith you can remove the better, since shrinkage around the pith can be radical. Cutting a blank from the outside section of a really big log is nice. I cut the other side to remove bark and flatten the blank. The thinner the blank, the more likely it is to survive. I usually cut the bark and some sapwood from the sides as well (depending on the wood) so I have a rectangular block. Since I like spindle turning, I generally prepare a number of smaller blocks as well - these will survive where a large block won't.
Be sure to cut out all existing cracks and checks on the end grain before sealing. If small cracks are left, they will turn into big cracks. The best way I know to see if all the cracks are gone is cut off a thin slice on the band saw and bend it. It will break easily along even an invisible crack.
If I have time, I like to cut the blank round with the bandsaw and even put it on the lathe between centers and turn it into a cylinder. This leaves less wood where cracks can begin AND it gives me a much better idea of the figure in the wood at turning time.
If I choose to keep an existing crack in the blank, say, if it is on a corner and I don't think it will be a problem or if the wood is one that is usually stable, I trace over it with a fat red sharpie pen before sealing - this reminds me of the crack at turning time so I can check it or turn around it.
I seal the ends with a thick coat or two coats of Anchorseal and seal a little bit up the sides from the ends. On some wood which has extreme shrinkage differences between the juvenile wood and the rest of the heartwood, I also coat a strip down the middle of the blank where the pith was removed. On blanks with a lot of figured grain (burl, etc.), I coat all the way around. I stack the sealed blanks loosely for a few days.
I store these blanks indoors in my garage which is not cooled or heated. If small enough, I put them into plastic tubs with no lids. I think that tends to keep the humidity high and slow drying. On woods that are prone to crack severely, I check them a few days and then a few weeks after processing. If I see any cracks, I put them back on the bandsaw and cut away the cracks and reseal. I like to put large blanks on wire shelves. They will probably mold on the bottom if stored flat on the floor or a shelf.
Anything you can do to increase the humidity will help. As long as you don't store flat wood in contact with flat wood, the chance of discoloration and loss by mold is minimal. BTW, in the "old" days, sawmills kept entire logs in a pond to keep them from degrading over extended times. I read somewhere that method has been banned due to water quality issues.
>I too live in Va. If the wood is in the log stage just seal the ends and keep it out of the sun. This will give you more time to rough out the bowls.
You will get some checking but usely you can cut the log back 4-5 inches and then cut your blanks as long as the log is wide. Then you will have to turn the blanks or they will crack.
>Everything I've read on this thread so far is very good advice... some is new to me, too. But I will add this. If it's nut wood or fruit wood (or any wood that cracks easily), you can put the cut blanks into a barrel of water for a few days until you get the time to rough turn them and seal them to dry.
Putting them into water will keep them from drying out and stressing the wood. I always take them out of the water a day before I'm planning to rough them out. This lets the free water escape and keeps the mess down when turning.
>With regards to immersing fresh cut logs in water it is not infallible! In fact if the log is left in the round cracking occurs within 3 or 4 days and after a week or 2 it will crack from one end to the other. Been there and done that with Oak, Mulberry and Ash. I would add that branch wood is a real pain and also it does depend what time of the year the wood is cut.
There is some benefit in immersing wood in flowing water as it tends to replace some of the sap but it is minimal. There is no surefire way of preventing cracks and although they can be minimized as others have suggested you should expect at least a 30% loss due to cracking.
>If youhave enough shavings, bury the log sections in the shavings, even wetting them down, then cover with a tarp. Warm humidity is good for the log sections.
>Best advice from Dick Hines, IMHO. For long term storage (more than a few days), leave the logs as long as feasible and seal the ends. Store off the ground, protected from sun and rain. When ready to turn one piece, cut log end back to unchecked wood as mentioned, cut off one piece and remove pith, seal one piece as previously stated, seal the cut end of the log, and rough turn the remaining piece to a thickness that is 10% of the diameter. Take your choice of methods to dry rough turnings.
I have recently downsized my lathe, my shop and my turnings. I no longer want to delve into mass rough out sessions, but did not want to lose nice wood, because I could not get to it.
>I agree with Allen however if I only need to keep the wood for a week or so before turning I simply put it in a trash bag. You do get some slight mold on the outside but in a week it hasn't had time to get inside. This will work with whole logs, cut blanks or roughed out bowls. In fact I use this method to stop a bowl from warping or checking while I take a dinner break.
